making reproduction parts for your Honda
Check out this section of Jay Leno's Garage by clicking here .
He has a 3-D scanner and printer which allows him to make the impossible to find parts needed for his cars.   While the 3-D printer is still a bit spendy for your home shop,   the scanner doesn't seem so bad in price at $3000.  Especially when you consider the amount of work needed to create a drawing of a part to give to a machinist.   This creates the CNC code which you can take down to the shop and have them make your part.  I'm not sure how many hours of CNC operation amounts to the $15,000 needed to buy the 3-D printer.
TOM THIES
Re: making reproduction parts for your Honda
Post by TOM THIES »
Doesn�t Jay have a Honda 600?  Hmmmmm.  We have  got to get Jay into our group so we can use that 3d for our cranks.
Tom T
> goinhm@...
> Tuesday, June 01, 2010 2:52
> [2cylinderhondas] making
> here
> He has a 3-D scanner and printer which allows him to make the impossible to > find parts needed for his cars.   While the 3-D printer is still a > bit spendy for your home shop,   the scanner doesn't seem so bad in > price at $3000.  Especially when you consider the amount of work needed > to create a drawing of a part to give to a machinist.   This creates > the CNC code which you can take down to the shop and have them make your > part.  I'm not sure how many hours of CNC operation amounts to the > $15,000 needed to buy the 3-D printer.
CHEYENNE FLETCHER
Post by CHEYENNE FLETCHER »
This is trick prototyping. It's been around for years. It wrights a "G" code program for the CNC machining center to follow. You can however do the same thing manually in only a little time you just need the measuring equipment :dial calipers, Mikes, Etc. I did a lot of proto typing for WLGore. They had one of those scanners and would bring us the part and the program so we could run it.
They are quite accurate but still need tweeking for holes and reliefs.
> goinhm@...
> here
CHEYENNE FLETCHER
I have an extra crank if your interested.
> TOM THIES
> Tuesday, June 01, 2010 8:00
> Re: [2cylinderhondas] making
> Doesn't Jay have a Honda 600?  Hmmmmm.  We have  got to
> Tom T
> > goinhm@...
> > AM
> > here
> > He has a 3-D scanner and printer which allows him to make the impossible to > > find parts needed for his cars.   While the 3-D printer is still a > > bit spendy for your home shop,   the scanner doesn't seem so bad > > in price at $3000.  Especially when you consider the amount of work > > needed to create a drawing of a part to give to a machinist.
> > This creates the CNC code which you can take down to the shop and have them > > make your part.  I'm not sure how many hours of CNC operation amounts > > to the $15,000 needed to buy the 3-D printer.
> > Dale
misterpoopoohead
Post by misterpoopoohead »
It's nice to have money! ;o)
Kevin's Sent from my Verizon Wireless BlackBerry
goinhm@...
Date:
Tue, 1 Jun 2010 05:52:07 EDT
[2cylinderhondas] making reproduction parts for your Honda
bottom cop
Post by bottom cop »
If he does not, someone should donate him one just to grab his interest.
Tue, 6/1/10, TOM THIES
> From: TOM THIES
> Subject: Re: [2cylinderhondas] making reproduction parts for your Honda > To: 2cylinderhondas@yahoogroups.com > Date: Tuesday, June 1, 2010, 11:00 AM
> Doesnt Jay have a Honda 600?  Hmmmmm.  We have  got to get Jay into our group so we can use that 3d for our cranks.
> Tom T
> > goinhm@...
> > Tuesday, June 01, 2010 2:52 AM
> > here
> > .  He has a 3-D scanner and printer which allows him to make the impossible to find parts needed for his cars.   While the 3-D printer is still a bit spendy for your home shop,   the scanner doesn't seem so bad in price at $3000.  Especially when you consider the amount of work needed to create a drawing of a part to give to a machinist.   This creates the CNC code which you can take down to the shop and have them make your part.  I'm not sure how many hours of CNC operation amounts to the $15,000 needed to buy the 3-D printer.
> > Dale
Post by lyletrudell »
Dale that 3D scanner is a useful tool for a CNC machine shop.
I don't have one, but thought about it over the years.
Have seen them at tool shows and a couple local shops have them.
They are limited but have there uses.
I just measure and draw the part in CAD then create a G-code file from it. Pretty quick way and my part is ready to use.
For Jay it's great, he doesn't have to incorrectly measure the part and send the wrong dimensions to the machine shop.
He only needs to push a button and produce one plastic solidified part that he can try to put on his car.
But, he will still have to use the "error-prone" machine shop to get an accurate working part.
> --- On Tue, 6/1/10, TOM THIES wrote:
> From: TOM THIES
> Doesn’t Jay have a Honda 600?  Hmmmmm.  We have  got to get Jay into our group so we can use that 3d for our cranks.
> Tom T
> From: goinhm@...
> Sent: Tuesday, June 01, 2010 2:52 AM
> Subject: [2cylinderhondas] making reproduction parts for your Honda
> Check out this section of Jay Leno's Garage by clicking here.  He has a 3-D scanner and printer which allows him to make the impossible to find parts needed for his cars.   While the 3-D printer is still a bit spendy for your home shop,   the scanner doesn't seem so bad in price at $3000.  Especially when you consider the amount of work needed to create a drawing of a part to give to a machinist.   This creates the CNC code which you can take down to the shop and have them make your part.  I'm not sure how many hours of CNC operation amounts to the $15,000 needed to buy the 3-D printer.
Love
Post by Love »
Jay has an S500 (or was it a S600).  Mark M. Told me a few years ago, at a Monterey car show, a stuntman had a 600 sedan bolted to a helmet (it spun when lifted).  Jay was there and called it a Mini.
Bruce Dewing Santa Clara, CA
Tom T
> goinhm@...
> here
Love
Post by Love »
Jay has an S500 (or was it a S600).  Mark M. told me a few years ago, at a Monterey (Pebble Beach Concours) car show, a strongman had a 600 sedan bolted to a helmet (it spun when lifted).  Jay was there and called it a Mini.
Tom T
> goinhm@...
> here
CHEYENNE FLETCHER
I saw him driving it on TV (My Classic Cars with Dennis Gauge, I think his name is)It was a small convertible light blue metallic revved to the moon and looked cool as heck. I can only dream of finding one of those.
> Bruce Dewing
> Tuesday, June 01, 2010 10:52
> Jay has an S500 (or was it a S600).  Mark M. told me a few years > ago, at a Monterey (Pebble Beach Concours) car show, a strongman had a 600 > sedan bolted to a helmet (it spun when lifted).  Jay was there and called > it a Mini.
> Bruce Dewing
> Santa Clara, CA
> On Jun 1, 2010, at 8:00 AM, "TOM THIES" tdthies1@msn. com
> > Tom T
> > > goinhm@...
> > > anzhonda600owners@
> > > yahoogroups. com
> > > 2cylinderhondas@
> > > yahoogroups. com
> > > Sent:
> > > AM
> > > Check out this section of Jay Leno's Garage by clicking > > > here > > > .  He has a 3-D scanner and > > > printer which allows him to make the impossible to find parts needed for > > > his cars.   While the 3-D printer is still a bit spendy for your > > > home shop,   the scanner doesn't seem so bad in price at > > > $3000.  Especially when you consider the amount of work needed to > > > create a drawing of a part to give to a machinist.   This > > > creates the CNC code which you can take down to the shop and have them > > > make your part.  I'm not sure how many hours of CNC operation amounts > > > to the $15,000 needed to buy the 3-D printer.
> > > Dale
