Hi JD,
The wire from the condensor and the blue wire going into the ignition housing will both connect to the points. One side of the points is grounded via the two mounting screws. The other side of the points is a small nut and bolt combo which is insulated...... this is where the two wires (condensor wire and the blue wire) will connect. If you measure the resistance where the wires connect to the points, it will show (a) high resistance when the points are open and (b) low resistance when the points are closed. If you get these readings, the wires are correctly connected and not shorting to the case.
> If
> anyone has anything that would be great!
> I have the manuals haynes and the
> online one but the pictures are not to helpful so a picture in color or at > least a good description where the wire go.
> Thanks
> everyone
> JD
Thanks that helps I was working on the valves and my bro took it apart without me getting to look at it.
Merry Christmas
JD
--- In 2cylinderhondas@yahoogroups.com
, goinhm@... wrote:
> Hi JD,
> good luck,
> If anyone has anything that would be great!
> I have the manuals haynes and the online one but the pictures are not to
> helpful so a picture in color or at least a good description where the wire
> go.
> Thanks everyone
> JD
