New Old Stock parts for sale
Campbell
Post by Campbell »
I have sold all three of my Z600s but I have 22 boxes of new old stock parts and good secondhand spares. Now the time has come to sell them off.
Many of the spares I have are for the N360/N600 and Z600 but some will fit the TN Models too. I have listed with part number and where know, which models they fit, so if it says it fits N360/N600/TN360 and Z600 - it will indeed fit all of these models.
All are packaged as new - but do accept that these parts are 40 years old and packages have been opened to count numbers and check items.
Postage will be at cost plus �1.00 for packaging materials and I am happy to combine shipping. I don't want the hassle of trying to find parts for everyone - there's too much to do that so will be listing it as I sort it out. All items will be sent airmail at YOUR expense and a certificate of posting will be acquired for everything mailed out. If you want it sent insured/signed for, I will do that but again at your cost.
You can e-mail me on campbellmccutcheon A T googlemail (dot) com if anything takes your fancy.
Prices are in UK Pounds (about $1.50 to the pound just now).
This is Box 1!
30200-551-044 Ignition Advance mechanism mechanical spark N360, N and Z600 �20.00
35180-568-812 Light Switch N600 �10.00
53210-538-040 Steering Column Cover N360 and N600 �10.00
84104-568-811 Bumper overrider N600 �15.00
54211-538-010 Gaiter N360 �15.00
62621-568-813 Bumper overrider N600 �15.00
62622-568-812 Bumper overrider N600 �15.00
14555-551-010 Seat, tensioner spring, camshaft, rocker arm N600, N360 �0.50
90505-568-000 gasket, drain plug fuel tank (x10) N600 �2.50
44316-538-008 Band, joint bellows, driveshaft gaitor x 3 N600, Z600 �4.00
91101-551-004 Bearing, 6201 cooling fan Z600, N360 �3.00
05722-542-000 Spacer �1.00
18354-542-000 2 Bushes �1.00
43131-538-000 Retainer, adjusting cam, rear brake x 4 N360, N600 �4.00
30200-568-014 Ignition Advance mechanical spark N600, Z600 �20.00
14462-551-500 Chain clip N360 �1.00
91103-551-032 Roller bearings x 10 N360 �6.00
91211-551-003 2 bearings �5.00
39237-538-010 Clamp, heater air duct N360, Z600 �2.00
18354-542-000 Bearing x 2 �4.00
85713-538-040 Pin, hinge pivot � engine cover hinge x 2 N360, N600 �2.00
18208-542-000 Fibre spacer x 2 N360 �3.00
43132-538-022 Little geared cam x 2 N360 �4.00
90652-538-000 Clip, 2/3-way joint front brake line x 4 N360, N600 �3.00
83512-542-000 Bush plus washer N360 �3.00
14740-551-020 Cam/valve lifters x 2 �8.00
90107-538-010 2 bolts �3.00
91326-568-003 O Rings 10x2 crankcase x 19 N600 �4.00
54211-601-000 Bellows, gear shift rod, Gaiter N3-360, Z600, N600 �15.00
14456-551-010 Circlip (1) N360 �0.50
05721-542-000 Spacer �1.00
13466-551-010 Spring �1.00
34136-568-600 Light lens �4.00
54121-609-500 ? x 4 N360Z AT �4.00
31257-568-005 Clip pinion stopper starter motor x 2 N600, Z600 �1.00
31271-568-005 Washer A Thrust, starter motor 1.6mm x 2 N600, Z600 �0.50
15429-551-000 Pipe, oil passage, crankcase N360 �1.00
39283-538-000 Spring clips x 14 �2.00
38513-538-000 Clips, windscreen washer reservoir, rear x6 N360, N600 �4.00
46472-568-000 Front disc brake, gasket, oil bolt x 2 N600, Z600 �1.00
46130-568-810 Spring x 4 N600 �2.00
14745-551-050 camshaft, rocker arm lifter, right ARM R. N600, N360, Z600 �6.00
14551-551-010 Push rod, tensioner, cam shaft rocker arm N600, N360 �1.50
42323-538-030 6 x cupped washers �2.00
90420-551-000 Plate, filter element seal setting, crankcase x 7 N360, N600, Z600 �2.00
66458-542-000 3 springs �2.00
22628-580-003 2 unknown N600AT �3.00
90315-538-316 Nut, pipe joint clamp exhaust system x 6 N360, N600 �3.00
31255-568-005 Stopper, pinion shaft, starter motor N600, Z600 �1.00
14711-568-010 Valve, inlet N600, Z600 �5.00
31267-568-005 Washer, pinion sleeve, starter motor x 6 N600, Z600 �3.00
91256-538-003 Oil seal, o-ring rear wheel bearing cap N360, N600, Z600 �2.00
All items sold on a first come first serve basis - paypal preferred.
If there are any questions, or you need pics, do let me know. Otherwise, here's a taster of the quantity of bits
http://www.flickr.com/photos/46466362@N ... 922811015/
mckinney
Re: New Old Stock parts for sale
Post by mckinney »
Did I spy a front strut for a sedan or a coupe in the pictures?  I am searching for a pair of sedan struts if possible.
Thanks, Bryan On Mar 10, 2011, at 1:50 PM, campbell.mccutcheon@...
> This is Box 1!
> 85713-538-040 Pin, hinge pivot engine cover hinge x 2 N360, N600 �2.00
Campbell
Post by Campbell »
Bryan
there is a single new strut - it has some light rust from storage but is otherwise brand new.
It has no part number so you will need to check it fits your car. I would have thought that the struts would be the same for coupe and sedan but I can cross-ref the parts from the parts lists for both models and see if the strut is interchangeable. Not light so postage from UK may be expensive - certainly, from experience about $60-70 for airmail alone, but maybe more.
Campbell
> Thanks, Bryan
> > sell them off.
> > items.
> > This is Box 1!
> > and Z600 �20.00
> > and Z600 �20.00
> > and Z600 �20.00
> > and Z600 �20.00
> > N360 �0.50
> > �4.00
> > �2.00
> > �3.00
> > �15.00
> > �0.50
> > N600 �4.00
> > Z600 �6.00
> > �1.50
> > �3.00
> > �3.00
> > Z600 �2.00
Alan Stanyon
Post by Alan Stanyon »
I would like to just stand and drool !!!!! these bits are like rocking horse s**t in the uk i assume your up north somewhre i am in kent, luckily i have managed to get all i need for the moment Cambell nice pictures!
Alan
Date: Fri, 11 Mar 2011 09:00:22 +0000
Subject: [2cylinderhondas] Re: New Old Stock parts for sale
Bryan there is a single new strut - it has some light rust from storage but is otherwise brand new.
Campbell
, McKinney wrote:
> Did I spy a front strut for a sedan or a coupe in the pictures? I am > searching for a pair of sedan struts if possible.
> Thanks, Bryan
> > I have sold all three of my Z600s but I have 22 boxes of new old > > stock parts and good secondhand spares. Now the time has come to > > sell them off.
> > Many of the spares I have are for the N360/N600 and Z600 but some > > will fit the TN Models too. I have listed with part number and > > where know, which models they fit, so if it says it fits N360/N600/ > > TN360 and Z600 - it will indeed fit all of these models.
> > All are packaged as new - but do accept that these parts are 40 > > years old and packages have been opened to count numbers and check > > items.
> > Postage will be at cost plus �1.00 for packaging materials and I am > > happy to combine shipping. I don't want the hassle of trying to > > find parts for everyone - there's too much to do that so will be > > listing it as I sort it out. All items will be sent airmail at YOUR > > expense and a certificate of posting will be acquired for > > everything mailed out. If you want it sent insured/signed for, I > > will do that but again at your cost.
> > You can e-mail me on campbellmccutcheon A T googlemail (dot) com if > > anything takes your fancy.
> > This is Box 1!
> > 30200-551-044 Ignition Advance mechanism mechanical spark N360, N > > and Z600 �20.00
> > 14555-551-010 Seat, tensioner spring, camshaft, rocker arm N600, > > N360 �0.50
> > 44316-538-008 Band, joint bellows, driveshaft gaitor x 3 N600, Z600 > > �4.00
> > 85713-538-040 Pin, hinge pivot engine cover hinge x 2 N360, N600 > > �2.00
> > 90652-538-000 Clip, 2/3-way joint front brake line x 4 N360, N600 > > �3.00
> > 54211-601-000 Bellows, gear shift rod, Gaiter N3-360, Z600, N600 > > �15.00
> > 31271-568-005 Washer A Thrust, starter motor 1.6mm x 2 N600, Z600 > > �0.50
> > 38513-538-000 Clips, windscreen washer reservoir, rear x6 N360, > > N600 �4.00
> > 14745-551-050 camshaft, rocker arm lifter, right ARM R. N600, N360, > > Z600 �6.00
> > 14551-551-010 Push rod, tensioner, cam shaft rocker arm N600, N360 > > �1.50
> > 90420-551-000 Plate, filter element seal setting, crankcase x 7 > > N360, N600, Z600 �2.00
> > 90315-538-316 Nut, pipe joint clamp exhaust system x 6 N360, N600 > > �3.00
> > 31267-568-005 Washer, pinion sleeve, starter motor x 6 N600, Z600 > > �3.00
> > 91256-538-003 Oil seal, o-ring rear wheel bearing cap N360, N600, > > Z600 �2.00
Campbell
Post by Campbell »
Alan
I am in Gloucester. It's the result of a long time accumulation of bits plus scrapping a few cars.
Campbell
Ps the bits are easier to find than bits for my mochet camionette and messerschmitt.
Sent from my BBC Model B
Alan
Bryan
Campbell
> Thanks, Bryan
> > This is Box 1!
Love
Post by Love »
Struts are different (sedan is shorter).
Bruce D.
Santa Clara, CA
"campbell.mccutcheon@..." To:
Fri, March 11, 2011 1:00:22 AM Subject:
Campbell
> Thanks, Bryan
> > This is Box 1!
spark N360, N
> > and Z600 �20.00
N360, N600
> > �3.00
> > 15429-551-000 Pipe,
> > 90315-538-316
> > �3.00
