Rear Brake fluid leakage
juniselect
Post by juniselect »
Hey fellow 600 enthusiasts,
Took the sedan out today and noticed there was a small puddle in the garage where the driver's side rear wheel rested. Looked closer and saw a small trickle of brake fluid down the inner side wall of the tire. Took off the wheel and inspected the rear brake cylinder. when i squeezed the rubber base of the cylinder i had brake fluid come out and when i let go, it seemed to "inflate" again. Didn't check to see if the other side, (which doesn't leak) because I wanted to pitch this situation to the group. Any ideas on what is going on?
Thanks so much!
Marty
San Francisco, CA
