I have a nice set of rear tail light assembles, both left and right complete with rubber for a N600, used however in very nice condition, the car was stored in doors for the last 24 years, nice steering wheel also. I still have two N600 Sedans, very nice complete cars and ready to go, you will not find two better cars for the price, nos parts for sale also, air filter, oil filter, gaskets, n600 hub caps and more. All parts and cars are located in North Carolina, email tmoc1990@...
web site honda600shop.com
n600 parts
Charles Gould
Re: n600 parts
Can anyone tell me if an original Honda gasket set for the N600 will also fit the Z600 engine and if not, which gaskets are different? What is an NOS Honda gasket set worth?
Thank you,
Chas Sent from my iPhone
Thank you,
On Apr 1, 2012, at 8:47 PM,
tmoc1990@...
web site
honda600shop.com
Don B Laughton
Re: n600 parts
The 600 top sets share the critical pieces, i.e. cam box, head, cam bearing, exhaust manifold and cylinder base gaskets. The early 600 has four round heat exchanger gaskets. (Actually, there is a flat portion on the edge so the the gaskets can fit closer together. The Z and late N use three two holed heat exchanger gaskets. The Z has a unique valve cover bolt pattern. If you install an engine with a sedan cam box and cover, you will put two dimples in the hood...oops. Both sets should have chain tensioner and intake manifold o-rings. I believe the coupe set has a tach drive seal to go with the "breaker" seal.
Hope this helps, Best Wishes, Don Laughton
Charles Gould
"2cylinderhondas@yahoogroups.com"
Sunday, April 1, 2012 5:52 PM
Re: [2cylinderhondas] n600 parts
Thank you, Chas Sent from my iPhone
Charles Gould
tmoc1990@...
web site
honda600shop.com
