What kind of carb is this
eric.geiger
Post by eric.geiger »
I posted this in the ANZ group as well but i figured id post here as there is almost 2x as many members. sorry if you get both.
can someone help me out with whether this is an early model or late model carb.
my car doesn't have the original engine and it seems the carb may not be from
the same model year.
here is a link to the picture
Thank you as always you are very helpful and in the future ill be sure to pay it
forward when i can help others with their 600's
Don Laughton
Re: What kind of carb is this
Post by Don Laughton »
It looks like an aluvil gold sedan. This was a late color, used on 72s. The engine number should be N600E-15XXXXX. The carb is correct for this synchromesh trans engine Don B. Laughton Sent from my iPhone
forward when i can help others with their 600's =
Post by Eric Geiger »
So if I needed to order a carb kit would I order the "late model" kit? the 33mm or 28mm
Eric J. Geiger
PRG Nocturne
XXX-XXX-XXXX phone
XXX-XXX-XXXX fax
XXX-XXX-XXXX mobile
egeiger@...
www.prgnocturne.com
Don B. Laughton
Sent from my iPhone
Don Laughton
The fact Don B. Laughton Sent from my iPhone
Eric J. Geiger
PRG Nocturne
XXX-XXX-XXXX phone
XXX-XXX-XXXX fax
XXX-XXX-XXXX mobile
egeiger@...
www.prgnocturne.com
> Don B. Laughton
> Sent from my iPhone
> On Apr 18, 2012, at 4:56 PM, "eric.geiger" egeiger@...
Sorry that last response confused me.
Eric J. Geiger
On Apr 19, 2012, at 12:50 AM, "Don Laughton" wrote:
The fact
Don B. Laughton
Sent from my iPhone
> Eric J. Geiger
> PRG Nocturne
> XXX-XXX-XXXX phone
> XXX-XXX-XXXX fax
> XXX-XXX-XXXX mobile
> egeiger@...
> www.prgnocturne.com
> On Apr 18, 2012, at 11:19 PM, "Don Laughton" dontranspac@...
> > Don B. Laughton
> > Sent from my iPhone
> > On Apr 18, 2012, at 4:56 PM, "eric.geiger" > egeiger@...
Don Laughton
The factory carb kit was gaskets and o-rings only. The float  valve, needle jet metering rod pump diaphragm etc had to ordered separately. The hot tip would be to order a kit for late N/Z600. The 2m is probably a 360 carb.
Don B. Laughton Sent from my iPhone The hot tip will
Eric J. Geiger
PRG Nocturne
XXX-XXX-XXXX phone
XXX-XXX-XXXX fax
XXX-XXX-XXXX mobile
egeiger@...
www.prgnocturne.com
> Don B. Laughton
> Sent from my iPhone
