starting problems
tmoc1990
starting problems
Post by tmoc1990 »
OK, lets see who has the right answer to the problem listed below.
AN600, removed and cleaned gas tank, new fuel filter and fuel line, adjusted point gap and timing, 155 psi compression, cam timing is spot on, new plugs and caps, removed point plate, cleaned and reassembled, fuel solenoid working fine, valve adjustment is correct also, now here we go, the car will only run when gas is poured in the intake or a shot of starting fluid is sprayed in the intake, and the carb was taken off of a daily driver with zero issues. The correct answer receives a NOS oil filter via pre paid shipping.
Re: starting problems
Post by Eric Geiger »
you didn't mention if the fuel pump was actually working?
Eric J. Geiger
PRG Nocturne
XXX-XXX-XXXX  phone
XXX-XXX-XXXX  fax
XXX-XXX-XXXX  mobile
egeiger@...
www.prgnocturne.com
On Nov 3, 2012, at 6:10 PM, OK, lets see who has the right answer to the problem listed below.
> AN600, removed and cleaned gas tank, new fuel filter and fuel line, adjusted point gap and timing, 155 psi compression, cam timing is spot on, new plugs and caps, removed point plate, cleaned and reassembled, fuel solenoid working fine, valve adjustment is > correct also, now here we go, the car will only run when gas is poured in the intake or a shot of starting fluid is sprayed in the intake, and the carb was taken off of a daily driver with zero issues. The correct answer receives a NOS oil filter via pre paid > shipping.
TOM THIES
Post by TOM THIES »
Well the first thing I see is that you said nothing about the fuel pump.
> tmoc1990@...
> Saturday, November 03, 2012 4:10
> [2cylinderhondas] starting
> problems
> OK, lets see who has the right answer to the problem listed > below.
> AN600, removed and cleaned gas tank, new fuel filter and fuel > line, adjusted point gap and timing, 155 psi compression, cam timing is spot > on, new plugs and caps, removed point plate, cleaned and reassembled, fuel > solenoid working fine, valve adjustment is correct also, now here we go, the > car will only run when gas is poured in the intake or a shot of starting fluid > is sprayed in the intake, and the carb was taken off of a daily driver with > zero issues. The correct answer receives a NOS oil filter via pre paid > shipping.
Ray
Post by Ray »
If you have fuel pressure it is the carb float,needle and seat or small fuel filter under the needle and seat
Sent from my iPhone
Don Laughton
Post by Don Laughton »
OK, has the  manifold been removed? If so, was the o-ring replaced?  Check the brake booster check valve. Remove the hose at the manifold plug the valve and see if the engine starts. To check the fuel pump, disconnect the hose at the pump, direct it into container and turn the key to the on position and see what happens Don B. Laughton Sent from my iPhone
On Nov 3, 2012, at 4:10 PM,
tmoc1990@...
twincarb600
Post by twincarb600 »
Is it truly running or just firing. If the crank pulley was 180 out you could probably get some sort of fire just from the raw fuel getting into the cylinders. That is why when carb is attached it is not drawing fuel in to the engine it is actually exhausting thru carb.
Terry-Jo Platt
Post by Terry-Jo Platt »
Needle & seat in carb stuck closed no gas in bowl
TOM THIES
Post by TOM THIES »
Air leak before fuel pump? Or did not clean fuel pick up pipe.   Do we have fuel at the carb?
Sent from my iPod
tmoc1990@...
michael w king
Post by michael w king »
Check fuel pressure at carb feed hose. possible reversed fuel lines at
pump.
Penny Stock Ready to Soar
Small Stock Set to Skyrocket Over 1,000%
http://thirdpartyoffers.juno.com/TGL314 ... f51st01duc
David Baer
Post by David Baer »
carb needle and float assy stuckor contaminated�from debris in fuel line after the fuel filter.
On Sat, Nov 3, 2012 at 4:10 PM,
David F. Baer
469 Ena Rd., Apt. #1311
Honolulu, HI 96815
Cell:� XXX-XXX-XXXX
