You may have a problem doing the sedan carpets like original. The center carpet is all one piece bonded/formed with plastic backing to form around the tunnel and up to the shifter.
--- In 2cylinderhondas@yahoogroups.com
, Eric Geiger wrote:
> Currently I'm only doing a coupe set. As that's what car I have. Ill be doing sedan over the summer probably.
> Eric J. Geiger
> PRG Nocturne
> XXX-XXX-XXXX phone
> XXX-XXX-XXXX fax
> XXX-XXX-XXXX mobile
> egeiger@...
> www.prgnocturne.com
> On Feb 8, 2013, at 8:24 AM, "Dave Douglass AIA" > wrote:
> They look really nice, what will you be wanting for a sedan set?
, "eric.geiger" wrote:
> > Hey all, I've been working on a new reproduction carpet that will match the original almost exactly. it will have the same style loop pattern and sewn binding as the original OEM carpet.
> > Check out the sample photos here compared to my original 40yr old carpet, i think you'll be impressed.
> > I will have comparison photos next week comparing the reproduction samples next to a set of NOS carpet for an even better look at how close the product will be to original.
> > Enjoy:
Thanks for the heads up ill have to take a close look at it then.
> Eric J. Geiger
> PRG Nocturne
> XXX-XXX-XXXX phone
> XXX-XXX-XXXX fax
> XXX-XXX-XXXX mobile
> egeiger@... www.prgnocturne.com
> > Enjoy:
