Brake Booster
Brake Booster
Need help to find good used late model brake booster or good
rebuilder
1972 Az600
Thanks
Ray
rebuilder
1972 Az600
Thanks
Ray
Re: Brake Booster
All USA coupe boosters are same
> rebuilder
> 1972 Az600
> Thanks
> Ray
Ryan Powell
Brake Booster
How do you get part number 4 out? the relay piston assy. Mine is frozen.
Schematic attahced
Schematic attahced
Re: [anzhonda600owners] Brake Booster [1 Attachment]
I used a small drill bit and was able to drill it out to the point where it became unfrozen then just used a new one. Miles used to make new ones otherwise u can probably get one used somewhere.
PRG-Nocturne
XXX-XXX-XXXX
Egeiger@...
On Dec 14, 2014, at 5:13 PM, Ryan Powell
ryanpowell96@...
[anzhonda600owners] How do you get part number 4 out? the relay piston assy. Mine is frozen.
> Schematic attahced
PRG-Nocturne
XXX-XXX-XXXX
Egeiger@...
ryanpowell96@...
> Schematic attahced
Let me clear that up I used a drill bit/easy out to yank it out. I didn't drill it out to the point where the drill bit touched the wall of the brake booster cylinder.
PRG-Nocturne
XXX-XXX-XXXX
Egeiger@...
On Dec 14, 2014, at 5:17 PM, Eric Geiger
egeiger@...
[2cylinderhondas] I used a small drill bit and was able to drill it out to the point where it became unfrozen then just used a new one. Miles used to make new ones otherwise u can probably get one used somewhere.
> Eric Geiger
> PRG-Nocturne
> XXX-XXX-XXXX
> Egeiger@...
> ryanpowell96@...
> [anzhonda600owners] anzhonda600owners@yahoogroups.com
> > Schematic attahced
PRG-Nocturne
XXX-XXX-XXXX
Egeiger@...
egeiger@...
> Eric Geiger
> PRG-Nocturne
> XXX-XXX-XXXX
> Egeiger@...
> ryanpowell96@...
> > Schematic attahced
David Brink
I have had success boiling master cylinders in water. Brake fluid is water soluble and there is the heat expanding things a bit.
On Sun, Dec 14, 2014 at 3:19 PM, Eric Geiger
egeiger@...
[2cylinderhondas]
> Let me clear that up I used a drill bit/easy out to yank it out.� I didn't drill it out to the point where the drill bit touched the wall of the brake booster cylinder.�
> Eric Geiger
> PRG-Nocturne
> XXX-XXX-XXXX
> Egeiger@...
> egeiger@...
> > I used a small drill bit and was able to drill it out to the point where it became unfrozen then just used a new one. � Miles used to make new ones otherwise u can probably get one used somewhere.�
> > Eric Geiger
> > PRG-Nocturne
> > XXX-XXX-XXXX
> > Egeiger@...
> > ryanpowell96@...
> > [anzhonda600owners] > anzhonda600owners@yahoogroups.com
> > > Schematic attahced
ryanpowell96
Re: Brake Booster
Does anyone have part number 4 for sale?
Sent from my Samsung Galaxy Note� II
Date:12/14/2014 5:13 PM (GMT-06:00)
To: 2cylinderhondas@yahoogroups.com, anzhonda600owners@yahoogroups.com
Subject: Brake Booster
Schematic attahced
Schematic attahced
Re: [anzhonda600owners] RE: Brake Booster
I'm sure I have one but again everything of mine is in storage so it'll probably be a week before I could look
PRG-Nocturne
XXX-XXX-XXXX
Egeiger@...
On Dec 14, 2014, at 7:35 PM, ryanpowell96
ryanpowell96@...
[anzhonda600owners] Does anyone have part number 4 for sale?
> Sent from my Samsung Galaxy Note® II
> From: Ryan Powell
> Schematic attahced
PRG-Nocturne
XXX-XXX-XXXX
Egeiger@...
ryanpowell96@...
> From: Ryan Powell
> Schematic attahced
I found the booster part 4 that I had originally pulled out before replacing it with a new one. It's got a tiny hole in the top from the easy out but if u want it it's yours for free just cover shipping. Email me direct.
PRG-Nocturne
XXX-XXX-XXXX
Egeiger@...
egeiger@...
> Eric Geiger
> PRG-Nocturne
> XXX-XXX-XXXX
> Egeiger@...
> ryanpowell96@...
> > Schematic attahced
PRG-Nocturne
XXX-XXX-XXXX
Egeiger@...
egeiger@...
> Eric Geiger
> PRG-Nocturne
> XXX-XXX-XXXX
> Egeiger@...
> ryanpowell96@...
> > Schematic attahced
Brake Booster
Does anyone have replacement diaphragms for the power chamber (big chamber) of a mid-series 5F5 Booster?
Skip
Skip
