removing Carburetor 72 Coupe
bobs600honda
Post by bobs600honda »
Quick question on getting the carb out.
Do I need to unbolt from intake manifold or can I remove by pushing backwards toward air filter.
Thanks for any suggestions.
Bob
Re: removing Carburetor 72 Coupe
Post by Eric Geiger »
you can push it out but you have to kind of rock it back and forth because the intake manifold black rubber is usually very stiff.   i usually take the air box off so i can get my hands around the carb easier.  if you take off the intake manifold have a new o-ring to install when you put it back together so you don't get a leak causing a bad idle.
Eric J. Geiger
PRG Nocturne
XXX-XXX-XXXX  phone
XXX-XXX-XXXX  fax
XXX-XXX-XXXX  mobile
egeiger@...
www.prgnocturne.com
> Bob
bobs600honda
Thanks, indeed a little rockin did the trick!
> Eric J. Geiger
> PRG Nocturne
> XXX-XXX-XXXX phone
> XXX-XXX-XXXX fax
> XXX-XXX-XXXX mobile
> egeiger@...
> Bob
