Coupe speaker size
eric.geiger
Coupe speaker size
Im looking to install a speaker in my coupe. what is the correct size? 3x5" I want something that will fit right in with no modifications. my car didn't come with a radio so i have nothing to compare to.
Nobutoshi Hayashi
Re: Coupe speaker size
I will check my dash of blue coupe which still has the factory speaker attached. I remember it was a little different way than normal how speaker was made and attached. Makes easier since dash is out of the car
I will take pics with tape measure so you will see the mounting holes etc. I won't be home from work till around 10 but I will send to you tonight.
Nobutoshi Hayashi
What made you decide to put speaker and cigarette lighter in your car?
I found a mp3 input device that's only like 3"x2"x1" so I'm gonna install it for my iPhone and also need a cigarette lighter assembly for GPS and phone charging.
Eric J. Geiger
PRG Nocturne
XXX-XXX-XXXX phone
XXX-XXX-XXXX fax
XXX-XXX-XXXX mobile
egeiger@...
www.prgnocturne.com
Eric J. Geiger
PRG Nocturne
XXX-XXX-XXXX phone
XXX-XXX-XXXX fax
XXX-XXX-XXXX mobile
egeiger@...
www.prgnocturne.com
I replaced the speaker in my Coupe some years ago; I believe it’s 4x6 – a common, cheap thing. I believe Autozone sells stuff like that for $10-$15. Does your Coupe have a center console, that holds the radio, cig lighter, etc? If so take a look at the back of it; hopefully there is a bracket for the speaker in place.
Steve www.honda600coupe.com
Eric, If you are looking to set up an amp/speaker setup for your iphone then you’ll need more than a cheapie speaker. An amplifier, a pair of speakers – it MIGHT fit in the stock console, if that’s your plan… it’s either that, or find other places around the car to install speakers.
I found a guy who makes input amps with a 1/8th in Audi jack and 2 amplified outputs for L/R speakers. It's specifically for classic cars with only 1 speaker in the dash. He also makes stereo speakers that fit into a 4x6" oval opening. It replaces the single mono speaker with 2 tiny speakers for L/R stereo but fits into the same opening.
Eric J. Geiger
PRG Nocturne
XXX-XXX-XXXX phone
XXX-XXX-XXXX fax
XXX-XXX-XXXX mobile
egeiger@...
www.prgnocturne.com
Eric J. Geiger
PRG Nocturne
XXX-XXX-XXXX phone
XXX-XXX-XXXX fax
XXX-XXX-XXXX mobile
egeiger@...
www.prgnocturne.com
On Jun 28, 2013, at 3:33 PM, "Steven Michelsen" wrote:
Eric,
If you are looking to set up an amp/speaker setup for your iphone then youll need more than a cheapie speaker. An amplifier, a pair of speakers it MIGHT fit in the stock console, if thats your plan& its either that, or find other places around the car to install speakers.
On Behalf Of
Friday, June 28, 2013 8:39 PM
> On Jun 28, 2013 4:10 PM, "eric.geiger" egeiger@...
