question about intake o-ring
hedoshedo2
Is the intake a ring special or can I use a universal o-ring
Re: question about intake o-ring
Just grab an off the shelf one.
PRG-Nocturne
XXX-XXX-XXXX
Egeiger@...
PRG-Nocturne
XXX-XXX-XXXX
Egeiger@...
On Sep 6, 2014, at 8:25 AM, "
heedo@...
The o-ring should be made of a material which does not deteriorate in the presence of gasoline and alcohol. It needs to be able to withstand the temperature of the engine at the intake. Nitrile o-rings are a common choice.
> one.
> Eric Geiger
> PRG-Nocturne
> XXX-XXX-XXXX
> Egeiger@...
> heedo@...
> [2cylinderhondas]" 2cylinderhondas@yahoogroups.com
