High-performance Camshaft
Sbcglobal
Post by Sbcglobal »
Hi Guys,
 I have a high-performance Camshaft it might be one of the Hawaiian cars camshaft just looking for peoples opinion on whether I should install that in my car, I wouldn't be changing the heads,  or the carburetion or the exhaust, just the Camshaft. Would  the engine still perform relatively smooth but just have a little bit more power that's my question?
 Elliot
David Brink
Re: High-performance Camshaft
Post by David Brink »
I would compare the cam with a stock cam, physically. Does it have more lift and or duration. Cams open the valves more or for a longer time to let more fuel/air in. So if it is doing anything it would need more fuel and air. Now if your engine presently always runs rich than a greater lift and duration might smooth things out. If the car is already lean than things could go bad.� Put the cam in. You can always drill out jets. You might need to have a less restrictive air and exhaust as well.
Don't forget matching valve springs if the cam is very different.
Or you could do what I did for a/f and timing. Build an EFI system with a Megasquirt ECU and Suzuki G10 throttle body. Lots of fun and didn't improve a thing.
On Thu, Jul 30, 2015 at 3:34 AM,
elliot62@...
[2cylinderhondas]
> Hi Guys,
> �I have a high-performance Camshaft it might be one of the Hawaiian cars camshaft just looking for peoples opinion on whether I should install that in my car, I wouldn't be changing the heads, �or the carburetion or the exhaust, just the Camshaft. Would �the engine still perform relatively smooth but just have a little bit more power that's my question?
> �Elliot
