Z600 Ignition coil? Or New Coil from a 2 cylinder motorcycle?
Sbcglobal
Post by Sbcglobal »
Hi Guys,
I'm looking for a NOS ignition coil for my car.. Or a good used one Also, could I use a new ignition coil from a new 2 cylinder motorcycle?
Elliot
Charles Gould
Re: Z600 Ignition coil? Or New Coil from a 2 cylinder motorcycle?
Post by Charles Gould »
Does anyone have an NOS or good used ignition switch, or can anyone provide advice as to how to repair mine. The spring that returns the key from the start position does not work, so that the switch tends to remain in the start position.
Are the switches easy to replace? How do you remove the switch collar and is it a shear bolt with rounded or recessed heads. If so, how do you grab it to remove the switch?
Thanks in advance for all of your help.
Chas Sent from my iPad
> Reply via web post
> Reply to sender
> Reply to group
> Start a New Topic
Note: 1 image(s) originally linked in this post are no longer available (fpc.pl).
kingtrans2003
Post by kingtrans2003 »
I take a die grinder or drill with a almost worn out 1/16" thick cut-off wheel and cut a slot in the exposed screw head. Then take a flat blade screw driver and remove them. Also makes the screws reuseable. hope this helps
On Mon, 14 Sep 2015 22:36:29 -0400 "Charles Gould chasgould@...
[2cylinderhondas]" Does anyone have an NOS or good used ignition switch, or can anyone > provide advice as to how to repair mine. The spring that returns the key from > the start position does not work, so that the switch tends to remain in the > start position.
> Are the switches easy to replace? How do you remove the switch > collar and is it a shear bolt with rounded or recessed heads. If so, how do > you grab it to remove the switch?
> Chas
> Sent from my iPad
> > Reply
> > via web post
> > Reply
> > to sender
> > Reply
> > to group
> > Start
> > a New Topic
Buffetts New Enemy
Buffett just confirmed his worst fear. Click here for his warning.
fool.com
dwb_07
Post by dwb_07 »
I used a single coil from a V6 Chevy coil pack. Look at this link and scroll down to picture. Not for purists.
My AN600s
My AN600s
I have (2) Honda AN600's which I found in an alley. $00!! One runs and the other has no roof and a broken timming chain. I am posting this picture to draw atten...
View on japanesenostalgicca...
Preview by Yahoo
Post by Eric Geiger »
I rebuild ignition coils all the time.   Unfortunately I'm out of town on business until 11/29
PRG-Nocturne
XXX-XXX-XXXX
Egeiger@...
On Sep 15, 2015, at 5:50 PM,
dwbrink@...
My AN600s
My
AN600s
View
on
Preview by Yahoo
Kevin Lister
Post by Kevin Lister »
Yes, I too have used a Dremel and cut-off wheel to cut slots in the heads of the screws. It definitely works and allows you to use a large screwdriver to screw them back in. ;o)
"kingtrans@... [2cylinderhondas]"
Tuesday, September 15, 2015 3:40 AM
Re: [2cylinderhondas] Z600 Ignition coil? Or New Coil from a 2 cylinder motorcycle?
> Chas
> Sent from my iPad
> > Reply
> > via web post
> > Reply
> > to sender
> > Reply
> > to group
> > Start
> > a New Topic
Buffetts New Enemy
fool.com
artremai
Post by artremai »
Whoever owned mine had a replacement added later on, my ignition is newer with standard bolts and I still have the original key.
Sent from my T-Mobile 4G LTE Device
From: "Kevin Lister misterpoopoohead@... [2cylinderhondas]"
Date:09/15/2015 2:01 PM (GMT-08:00)
Cc:
Subject: Re: [2cylinderhondas] Z600 Ignition coil? Or New Coil from a 2 cylinder motorcycle?
> Chas
> Sent from my iPad
> > Reply
> > via web post
> > Reply
> > to sender
> > Reply
> > to group
> > Start
> > a New Topic
Buffetts New Enemy
fool.com
