Brake line and fitting sizes?
Jayson Allen
Post by Jayson Allen »
Newbie with a '71 AN600.  My brake hard lines are pretty rough and many fitting nuts are rounded. Is it standard 3/16 line and 10mmx1.0 fittings? Any thoughts on line material? I see zinc steel and copper nickel options.
For example:
http://a.co/1F32pwe
Anything else I need to know... will a standard flaring tool work?
Thanks for your guidance!
Jayson
San Jose, CA
Jayson Allen
Re: Brake line and fitting sizes?
A little more research. Looks like the fittings could be 10mm x 1.25. Yes/no?
art Remai
Post by art Remai »
They are not a normal fitting, they have more thread on them, sourcing them are a pain in the butt. I found some online, just not sure if they will work.
Sent from my iPhone
On May 16, 2017, at 8:53 AM,
jayson_allen@...
Chuck Dean
Post by Chuck Dean »
I did an eBay search and found these:
http://www.ebay.com/itm/HONDA-600-COUPE ... KN&vxp=mtr
Chuck� Pleez x cuze enny tie ping or spelin air ores.
Our 1972 Honda 600 Coupe
On Tue, May 16, 2017 at 8:16 AM,
jayson_allen@...
[2cylinderhondas]
> Newbie with a '71 AN600.� My brake hard lines are pretty rough and many fitting nuts are rounded. Is it standard 3/16 line and 10mmx1.0 fittings? Any thoughts on line material? I see zinc steel and copper nickel options.
> For example:�
> http://a.co/1F32pwe
> Anything else I need to know... will a standard flaring tool work?� > Thanks for your guidance!
> Jayson
> San Jose, CA ��
Chuck Dean
I did a quick �eBay search and found these:
http://www.ebay.com/itm/HONDA- 600-COUPE-SEDAN-2-BRAKE-LINE- NUTS-FITTING-N600-Z600-BRAKES- MASTER-/381957290987?hash= item58ee6dbbeb:g: ZmoAAOSwcu5UQpKN&vxp=mtr I have bought from the seller before, he sells good used parts.
jayson_allen@...
[2cylinderhondas]
> For example:�
> http://a.co/1F32pwe
> Jayson
> San Jose, CA ��
Jayson Allen
Thanks Chuck. I went ahead and ordered those.
Looking at my lines, it appears to be a single flare. Is that correct or should it be a double?
Chuck Dean
It should be a double flare.
On May 16, 2017, at 2:08 PM,
jayson_allen@...
Jayson Allen
Thanks. Watching some youtube videos on applying a double flare and one indicates that there are both standard and metric flare tools. Do you know which tool I should use? Sorry for all the novice questions. Really appreciate the advice.
Chuck Dean
I'm pretty sure it's metric, although you may want to wait until one of the geniuses like Miles or Bill's answer.
Here's an excellent video on how to get really good double flares.
https://www.youtube.com/watch?v=4fmF9mm3hsM
On Tue, May 16, 2017 at 2:58 PM,
jayson_allen@...
[2cylinderhondas]
Jayson Allen
lol. That is the exact same video I watched.
