Re: Digest Number 78
OK, according to my 1967 Datsun 411 service manual, the front bearing race
is taped out with a drift punch from the opposite side of the hub. The
replace by using a bearing race and seal installation tool (what amounts to
being a flat plate the same OD as the race or seal) and tap it back in
place. Note if the hub is larger because of age and use, you may have to
use a pointed punch to dimple the surface where the race will seat to
enlarge the surface. This is done by "X-ing" the dimples numerous times to
keep the race centered when it is reinstalled. Or you can take it to a
machine shop and have it sleeved or welded to increase it's ID. I would say
look for another hub, but a used one may have the same problem.
If it is your rear axle, then it needs to be pressed off and pressed on
again as an assembly with the brake disc.
honda600js
Post by honda600js »
wow bill. I'm impressed you are versed in Datsun as
well! you are a man of many parts! I followed this
proceedure today and it all worked brilliantly. I
think I did the best bearing replace repack I ever
did. take care!
Ian
> and tap it back in
> race will seat to
> same problem.
> off and pressed on
> From: To: Sent: Saturday, August 17, 2002 7:03 AM
> Subject: [anzhonda600owners] Digest Number 78
> > There are 2 messages in this issue.
> > Topics in this digest:
> > 1. front wheel bearings, removal and
> replacement
> > From: Ian Kennedy > 2. Poll results for anzhonda600owners
> > From: anzhonda600owners
> > Message: 1
> > Date: Fri, 16 Aug 2002 18:05:10 -0700 (PDT)
> > From: Ian Kennedy > Subject: front wheel bearings, removal and
> replacement
> > OK kids, who's got a nice pleasant way to remove
> and
> > replace the wheel bearings on my '67 RL411. they
> are
> > the separate replaceable bearing race type.
> esentially
> > my question is, do I press the races in by
> cranking
> > the hub nut down or do I use a press, or what?
> > Ian
> > ".... An elegant weapon from a more civilized
> time..."
> > Do You Yahoo!?
> > HotJobs - Search Thousands of New Jobs
http://www.hotjobs.com
> > Message: 2
> > Date: 17 Aug 2002 07:29:15 -0000
> > Subject: Poll results for anzhonda600owners
> > The following anzhonda600owners poll is now
> closed. Here are the
> > final results:
> > POLL QUESTION: Tell me if you want an on line Car
> > Show. This would be open to all members
> > and voting would be by number given
> > pictures of cars submitted. Classes
> > would be Best Sedan, Best Coupe, Best
> > of Show and Needing most attention.
> > Winners would be displayed in a special
> > folder along with their winning event.
> > Each vehicle would be limited to 5
> > photos, all photos will be in JPEG, one
> > must show the engine compartment.
> > Points will be awarded for Original
> > equipment, Correct appearance, panel
> > fit, and Members choice of best of
> > show. Point categories to be posted
> > later along with voting forms. So give
> > me a yes or no and lets try and do this
> > up right
> > CHOICES AND RESULTS
> > - Yes, 12 votes, 100.00%
> > - No, 0 votes, 0.00%
> > INDIVIDUAL VOTES
> > - Yes
adal26@...
hondzilla@...
tmruwart@...
cab4word@...
riceburner006@...
gregsikes@...
amyshort@...
hondapenguin@...
harryL1190@...
iank71@...
billmyong@...
dk1bear@...
> > - No
> > For more information about this group, please
> visit
> > For help with Yahoo! Groups, please visit
http://help.yahoo.com/help/us/groups/
".... An elegant weapon from a more civilized time..."
Do You Yahoo!?
