Re: [2cylinderhondas] weatherstripping
Hi Neal;
J.C. Whitney has a pinch/bulb type weather strip for about $35.00 to do
both doors that I like to use. It's in a diamond or what they call a 1/2
bulb type of weather strip.
See attached.
Tom T.
    You can move the latch catch on the door post out a bit to allow the door to close easier, this will set the door out a bit but will allow it to close easier.   Then after a while you can move it back and it will close like before.  Slamming your door is never a good thing to do.  Besides causing the door to crack at the window brace (Coupe) it can jar the internal components of the door itself.
> 2cylinderhondas@yahoogroups.com [mailto:2cylinderhondas@yahoogroups.com] > On > Behalf Of > TOM THIES > Sent:
> Saturday, May 23, 2009 9:38
> Bill and James
> Thanks for the info.  Bill I am emailing them for information and > trying to get a small piece of material.  I will let all know what > happens.  I tried cutting the back side off of the weather stripping to > see if that would work and it did except that I still had to close the > door  hard so it came right back off.  I took it out for a spin > yesterday and the rebuilt carb I got on ebay made a huge difference in > running.  fixed the ruff idle and up and down running.
> thanks all
> Tom T
> > James
> > Hawkins
> > Saturday, May 23, 2009 6:38
> > AM
> > weatherstripping
> > Tom,   I used the ZX132561U and it's easy to put on and works > > good.  I have to slam the door a little harder than with the old > > collapsed trim. I didn't worry about the bottom as it was usable.  It > > might be tricky down there, price was $34.99 I > > believe.
> > > tdthies1
> > > Sent:
> > > Thursday, May 21, 2009 11:02
> > > PM
> > > [2cylinderhondas]
> > > weatherstripping
> > > well i tried the diamond shaped push on and the door wont even > > > close.the weatherstripping is ery thick, item No. 132562. MFG part no. uws > > > 1580-25. and know the item picture wont even show up on JC whitney.
> > > So can some one give me the item no. for the round push on > > > weatherstripping. .. i have called JC Whitney with NO help at > > > all.
> > > Thanks for any help
> > > Tom T
> > > No virus found in this incoming message.
> > > Checked by AVG -
> > > www.avg.com
> > > Version: 8.5.339 / Virus Database: 270.12.36/2126 -
> > > Release Date: 05/21/09 06:22:00
TOM THIES
Post by TOM THIES »
thanks Bill
Yeah I tried setting out the door but the weather strip was just to thick,  even cutting the back side off.  So what I did is take it all off and I have 10 foot of the thin stick on type and put 5 foot of each side so the door does not rattle.   I am trying to get some samples from a couple of other places to try.  so for now all is good until I get up to about 45 mph and the wind noise gets loud.  lol.   kind of nice to have a 70s radio station in the area to listen to when I am driving it.
everyone have a great weekend
Tom T
> billmyong@...
> Anzhonda600owners
> Sunday, May 24, 2009 6:06 AM
> [anzhonda600owners] RE:
> Tom
> T.
> the door post out a bit to allow the door to close easier, this will set the > door out a bit but will allow it to close easier.   Then after a > while you can move it back and it will close like before.  Slamming your > door is never a good thing to do.  Besides causing the door to crack at > the window brace (Coupe) it can jar the internal components of the door > itself.
> > On Behalf Of
> > TOM
> > THIES
> > Saturday, May 23, 2009 9:38 AM
> > Re:
> > Bill and James
> > Thanks for the info.  Bill I am emailing them for information and > > trying to get a small piece of material.  I will let all know what > > happens.  I tried cutting the back side off of the weather stripping to > > see if that would work and it did except that I still had to close the > > door  hard so it came right back off.  I took it out for a spin > > yesterday and the rebuilt carb I got on ebay made a huge difference in > > running.  fixed the ruff idle and up and down running.
> > thanks all
> > Tom T
> > > James Hawkins
> > > Sent:
> > > AM
> > > weatherstripping
> > > Tom,   I used the ZX132561U and it's easy to put on and works > > > good.  I have to slam the door a little harder than with the old > > > collapsed trim. I didn't worry about the bottom as it was usable.  It > > > might be tricky down there, price was $34.99 I > > > believe.
> > > > From:
> > > > tdthies1
> > > > To:
> > > > Sent:
> > > > PM
> > > > Subject:
> > > > [2cylinderhondas]
> > > > weatherstripping
> > > > well i tried the diamond shaped push on and the door wont even > > > > close.the weatherstripping is ery thick, item No. 132562. MFG part no.
> > > > uws 1580-25. and know the item picture wont even show up on JC whitney.
> > > > So can some one give me the item no. for the round push on > > > > weatherstripping. .. i have called JC Whitney with NO help at > > > > all.
> > > > Thanks for any help
> > > > Tom T
> > > > Checked by AVG -
> > > > www.avg.com
