dumb question #4 - proposed connections
mterrens
Post by mterrens »
Attached is a photo that shows connections I plan to make. I can only find
some of these on the wiring diagram; I am presuming the rest are correct,
given the like colors of the cables and the fact that each connection is the
"only place they could go". The red lines show the pairs I plan to connect.
Please take a look and comment.
This picture looks straight down. The bottom of the picture is the front of
the coupe. The battery can be seen on the left.
Re: dumb question #4 - proposed connections
Hi Steven;
In Picture #3, your correct. In Picture #4 you are also correct. However,
the three wires (White) going to the diode should be wrapped with shrink
tube on the back side and then put together and individually wrapped again
with electrical tape individually again and a rubber tube placed around all
the wires to prevent chaffing. And, always clean all connections (both
ends) then apply some Vaseline to the ends before pushing them together. It
will seal corrosion out and make getting them apart again later easier.
