TO Bill
LewetagK
TO Bill
Post by LewetagK »
Bill;
  DO you live in Oregon, if so can you drop me a line at lewetagk@...
Ken
In a message dated 1/11/2006 6:55:08 A.M. Pacific Standard Time, richard.morris@... writes:
> Bill,
> I am
> glad this is the USA, because I can voice a differing
> opinion.
> I
> firmly believe that you are wrong on the wires. By the way, are the original > wires carbon or copper centers? (Copper of course!).
> Here
> are a couple of points (no pun intended) to think on.
> 1.
> the original wires are copper center.
> 2.
> Race cars use copper center wire, not carbon center (drag racers, NASCAR, > etc)
> 3.
> Power line companies use copper wire, they are in the business of power > transmission. If it were economical, they would use silver or gold wire as > they conduct even better. (and the larger the diameter, the lower the > losses).
> 4.
> Your first sentence says the reason you use carbon center wires. You live in > California. The solid core wires create radio interference (i.e.: noise or > electrical pollution).
> 5. A common resistor (a current limiting device)
> is a carbon center. It is as bad as a low flow toilet. yes, they work, but I > want (and need) a power flush.
> Don't take offense at these responses, but legally,
> you can put solid core wires back on your Honda coil as the restrictions are > waived due to the vehicles age. Putting resistor wires on it is akin to > putting a cat converter on it. You don't have to do it.
> If
> you still think I am wrong, I am willing to send you a set of solid core wires > to try. Your car will start and run better.
> Richard
> Morris
Dave Douglass
Re: TO Bill
Post by Dave Douglass »
Hey
Is there any reason you can't run dual coils each firing on cylinder?  Anyone?
Dave LewetagK@...
> Bill;
> lewetagk@...
> Ken
> > Bill,
> > I am glad this is the USA, because I can voice a differing opinion.
> > I firmly believe that you are wrong on the wires. By the way, are the original wires carbon or copper centers? (Copper of course!).
> > Here are a couple of points (no pun intended) to think on.
> > 1. the original wires are copper center.
> > 2. Race cars use copper center wire, not carbon center (drag > > racers, NASCAR, etc)
> > 3. Power line companies use copper wire, they are in the business of power transmission. If it were economical, they would use silver or gold wire as they conduct even better. (and the larger the diameter, the lower the losses).
> > 4. Your first sentence says the reason you use carbon center wires. You live in California. The solid core wires create radio interference (i.e.: noise or electrical pollution).
> > 5. A common resistor (a current limiting device) is a carbon center. It is as bad as a low flow toilet. yes, they work, but I want (and need) a power flush.
> > Don't take offense at these responses, but legally, you can put solid core wires back on your Honda coil as the restrictions are waived due to the vehicles age. Putting resistor wires on it is akin to putting a cat converter on it. You don't have to do it.
> > If you still think I am wrong, I am willing to send you a set of solid core wires to try. Your car will start and run better.
> > Richard Morris
> > 2cylinderhondas@yahoogroups.com [mailto:2cylinderhondas@yahoogroups.com] > > On Behalf Of > > Bill Colford > > Sent:
> > Wednesday, January 11, 2006 1:31 AM
> > anzhonda600owners@yahoogroups.com; 2cylinderhondas@yahoogroups.com > > Subject:
> > RE: [2cylinderhondas] I want to replace sparkplug wires. What to use? Where to buy?
> > Spark Plug wires;
> >     In California, EPA has out-law'd sale of anything but carbon core > > wires for any vehicles but off road use.  This is because copper wire won't carry the current as effectively as carbon core wires do.  Here is an analogy that really fits.  Look at current as water running through a hose, copper wire is a water hose with no nozzle on the end of the hose so at full pressure it pushes the water a foot or so out the end.  Place a nozzle on the end of that same hose and it will shoot across the street.   Carbon core wire is like having a nozzle on the end of your wires.
> >     Will copper wire work, yep, but carbon core wires work better.  And, if I have a choice I want better.
> > > 2cylinderhondas@yahoogroups.com [mailto:2cylinderhondas@yahoogroups.com] > > > On Behalf Of > > > Richard Morris > > > Sent:
> > > Monday, January 09, 2006 7:50 AM
> > > Marshall,
> > > The wires are easily removed from the coil. Where the wires go into the coil, there is some glue. It is just on the outside and should be brittle. pop the glue free and twist the wire counterclockwise. This unscrews it out of the coil. Try it. Do not splice ignition wires, you will not get good results.
> > > Once the wire is out, look down into the hole in the coil, you will see the business end of a sheet metal screw that the wire screws onto.
> > > Richard Morris
> > > > From:
> > > > On Behalf Of
> > > > Marshall Montchalin
> > > > Sent:
> > > > Monday, January 09, 2006 9:40 AM
> > > > To:
> > > > Subject:
> > > > Re: [2cylinderhondas] I want to replace sparkplug wires. What to use? Where to buy?
> > > > Two thoughts, first about changing coils to get new wires, then about the chain:
> > > > About the wires -they are part of the coil, not attached separately as distributor-based cars do...HERE'S 2 ideas WHAT To do:
> > > > 1. Go to a motorcycle repair shop, I once went to a Harley shop and they sold me a fairly "hot" coil from a motorcycle after I explained that my supercar was 4four-stroke but fires  both cylinders at the same time liike a two-stroke.
> > > >  You just get an extra spark on the exhaust stroke for cleaner running performance.
> > > > If you don't have motorcycle shops, a lawnmower repair shop would > > > > work. The coil sparks through both plugs at the same time so a normal 12,000 volt coil might not be hot enough, but a motorcycle coil that puts out 18,000 volts might be about right, though you can run a HOT sparking coil without more penalty than mroe frequent replacement of points and plugs -no damage.
> > > > Motorcycles run the whole gamut of hot and cold coils, way more variety than cars, and your serviceman can guide you somewhat as to which coils are hotter.
> > > > OR
> > > > 2. YOU Can keep your coil and splice in regular car wires to the ends of your ignition coil, one on each end, from coil to left plug and from coil to right plug (unless the coil is as bad as the wires) with no distributor in the middle just come off each end of the coil secondary. The primary is grounded on one end and the other goes to your points.
> > > > Once you time the engine, you will know if you must move the chain: Very dangerous if you drop the > > > > chain into the engine! Use a coat hangar to hook one end of the chainlink so nothing can fall, while keeping a finger on the chain at the cam so you can count teeth.
> > > > Also know about the 600's sweet spot: my car liked to be one link back and all the way forward at the timing adjustment. Whatever makes it run the best. Don't change your chain tooth just anywhere, but rotate the engine to TDC and the cam should line up to its indexes as indicated in the manual. If you're off, then the chain is off.
> > > > Best wishes, Marshall
> > > > > I'm in the middle of a general tune up on my n600.  I replaced a bunch > > > > > of stuff today and I'm hoping to also replace my spark plug wires.
> > > > > Since I've never delt with a coil system (like this at least) before > > > > > I'm a bit confused.  I'm used to working on 90s civics where the spark > > > > > plug wires attach to the > > > > > distributor.
> > > > > Where can I get the proper wires/etc.?  Mine are slightly deteriorated > > > > > and I'd prefer to just get a good set on there.
> > > > > Any help is appreciated.
> > > > > Matt
> > > > '88 Plymouth Sundance 2.2l
> > > > Used-to-drive: Chrysler Simca 1204
> > > > Yahoo! Photos
> > > > Ring in the New Year with
> > > > Photo Calendars
> > > > . Add photos, events, holidays, whatever.
> Yahoo! Photos
> Got holiday prints?
> See all the ways
> to get quality prints in your hands ASAP.
tbwills
Re: TO Bill
Post by tbwills »
Richard is correct on this one.
The use of resistive spark plug wires is to reduce electrical
interference. The resistance increases the rise time of the voltage
when the coil fires. Increasing the rise time (we are taking about
nano-seconds to micro-seconds here) reduces the amount of energy
emitted in the frequency ranges used by radio equipment.
Do they reduce the amount of spark in the engine ? Not really because
when the high voltages needed to create a spark (approx 10,000V) are
produced, very little current is required, so the resistance doesn't
really matter. Once the spark is established, the voltage required to
maintain the spark is about 600V but the current is much much higher.
But again, the resistance doesn't matter because the coil can produce
plenty of voltage to overcome the (relatively) small resistance of
the leads.
That's why auto manufactures changed to carbon-core leads. Reduce
radio interferance is important for lots of the electronics in and
around a car.
Copper core is maily used in racing because they are chasing the last
0.1% of performance out of every component. Also, copper core is
stronger and not prone to internal cracking, which carbon core will
do with under racing conditions and repeated handling.
My AUS$0.02 worth.
Murray.
PS. In Australia, when the N600 were new, a common modification was to
add a resistor to one of the spark plug leads to reduce radio
interference.
On Thursday 12 January 2006 06:41,
LewetagK@...
> Bill;
_lewetagk@...
_ (mailto:
lewetagk@...
> Ken
richard.morris@...
writes:
> Bill,
> opinion.
> diameter, the lower the losses). 4. Your first sentence says the
> Richard Morris
] On Behalf Of Bill Colford
> Sent: Wednesday, January 11, 2006 1:31 AM
Subject: RE: [2cylinderhondas] I
> Spark Plug wires;
> core wires for any vehicles but off road use. This is because
]On Behalf Of Richard
> Morris Sent: Monday, January 09, 2006 7:50 AM
> Subject: RE: [2cylinderhondas] I want to replace sparkplug wires.
> Marshall,
> onto.
> Richard Morris
] On Behalf Of Marshall
> Montchalin Sent: Monday, January 09, 2006 9:40 AM
> Subject: Re: [2cylinderhondas] I want to replace sparkplug wires.
> about the chain:
> frequent replacement of points and plugs -no damage. Motorcycles
> are hotter.
> OR
> Very dangerous if you drop the chain into the engine! Use a coat
> chain is off.
> bunch of stuff today and I'm hoping to also replace my spark plug
> wires.
> before I'm a bit confused. I'm used to working on 90s civics
> where the spark plug wires attach to the distributor.
> deteriorated and I'd prefer to just get a good set on there.
> Matt
> Yahoo! Photos
> Ring in the New Year with _Photo Calendars_
http://us.rd.yahoo.com/mail_us/taglines ... a.yahoo.co
>m/*
http://us.rd.yahoo.com/mail_us/taglines/p
> hotos/evt=38087/*
http://pg.photos.yahoo.com/ph//page?.file=calendar
>_splash.htm l&.dir=) . Add photos, events, holidays, whatever.
Re: TO Bill
Post by Lyle »
Hi Murray;
I am attaching a file that says what you're saying but in terms much easier
to understand. Carbon Core wires will do the job better.
Please read the attached file. See what Aurora has to say about spark plug
wires.
Wayne Linschied
Re: TO Bill
Post by Wayne Linschied »
Don't know about anyone else, but I'm unable to read the attached
file (winmail.dat) with any thing!
Would like to know what it says as I tend to agree with Murray on
this one.
Wayne
---- Original Message ----
dana
Re: TO Bill
Post by dana »
Bill,
I guess I am getting a different read of this file than you are.
It still says that solid core wires are better than carbon core. It talks
about newer technology wire that use an alloy wire spirally wound and then
cover in carbon or graphite (some form of carbon). Again, the purpose of
these wires is to reduce ignition noise. It did not say that carbon core
wires are better than solid core wires.
What it is also talking about is ignition wire that is wirewound alloy with
carbon which is acting like a choke. A choke is a device used to reduce the
electrical interference (aka EMF).
One thing that I would worry about is how the screw that is in the coil,
that is designed to have a solid core wire threaded onto it is going to tear
up a carbon or spiral wound alloy and carbon wire. Typically, those wires
have a sharp pin stuck in their ends to work. if you mangle up the end on
them, there could possibly be a connection problem. It's just another reason
to stick with solid core wires.
If you are saying that you are using the wirewound (alloy means metal Bill)
carbon or graphite core wire, then that's fine. That will perform in a
manner similar to the solid core (stranded center) ignition wire. But in
terms of performance, the solid core center (stranded wire), is still going
to give better performance.
As was stated in a previous email by someone else, the initial spark is the
hottest and that is followed by the prolonged spark that completes the
burn. A sparks length is determined by voltage not amperage. However, the
ability to maintain the spark is dictated by available amperage, which by
using resistor wires or any device that introduces resistance in series with
the spark, will reduce to some degree, the available current (amperage).
I am not going to respond to any further emails on this subject as I see it
heading towards a pissing match. You are by far much more of the Honda 600
expert than I am, even though I have rebuilt (in the late 70's) somewhere
around 15 or 16 of them). I have been down the road of trying all sorts of
things to get these cars to run stronger, and one of the conclusions I came
to was that the solid core wires (again, the original wires are solid core)
with no resistor plug connectors, but the solid connectors and new silicone
boots, simply work better.
The bottom line here is that one or both of us has helped Matt with advice.
From all indications, his 600 runs better than ever. I for one am happy
about whichever way he did it.
Richard Morris
> Sent: Wednesday, January 11, 2006 10:53 PM
> Subject: RE: [anzhonda600owners] TO Bill
> Hi Murray;
> easier to understand. Carbon Core wires will do the job better.
> plug wires.
]On Behalf Of Murray Atkinson
> Sent: Wednesday, January 11, 2006 2:47 PM
> Subject: Re: [anzhonda600owners] TO Bill
> the leads.
> around a car.
> My AUS$0.02 worth.
> Murray.
> interference.
LewetagK@...
> > Bill;
_lewetagk@...
_ (mailto:
lewetagk@...
> > Ken
richard.morris@...
writes:
> > Bill,
> > opinion.
> > Richard Morris
> > [mailto:
> > Spark Plug wires;
> > [mailto:
> > Marshall,
> > onto.
> > Richard Morris
> > [mailto:
> > about the chain:
> > are hotter.
> > OR
> > chain is off.
> > wires.
> > Matt
> > Yahoo! Photos
> >m/*
> > hotos/evt=38087/*
SC
Re: TO Bill
Post by SC »
I agree with this statement Richard.  You both helped.  My car seems to run a lot better now, although it still has it's problems.
The only cables they had at Napa were carbon core.  They charged $9 for each and they were not long enough.  So I then went to Autozone and got two cables for $5 each.  Again all they had were carbon core.
They work fine, and my car is running much better as a result.  I'm still not used to the loud engine so I doubt I'll be using the radio any time soon.
> From all indications, his 600 runs better than ever. I for one am happy > about whichever way he did it.
> Richard
> Morris
Yahoo! Photos
Got holiday prints? See all the ways to get quality prints in your hands ASAP.
Re: TO Bill
Post by Lyle »
The article;
It is a MS 2K word file, I could have sent it as an e-mail I guess.
Most MAC computers read word now anyway.
Back to the issue of what wires to use. The article brings out two
points, first that solid wire was used first to transfer the energy to the
spark plug and is most efficient. But, it also has to be a larger diameter
to do the same work as a carbon core wire. (Read where the article starts
talking about Aurora's Design.) Since the wire diameter for the Honda Coil
is just under 8mm the 7mm carbon core wire is the best fit. As the
article also defines the construction of both wires it also tells of the
differences between the various makes. e.g. The Chevy 427 uses solid wire's
but every wire has a coil of wire wrapped around each which is grounded and
they must be run in a specific pattern so as not to cross the wires and have
spark jump between them. Second, The article also makes specific reference
to RFI as Murray did. And the article explains the term "Hotter Spark" but
all that is needed is transfer of current. Here is where the difference is,
as you are well aware the solid core wire breaks down its insulation and
arcs to the body (Honda double wrapped them to prevent chaffing against the
body and engine shrouds) but as time went on many Honda 600 coils were
tossed just because the wire insulation cracked or leads broke off or the
ends didn't screw in any more. If you noticed the original terminals were
shrouded in metal which was there to suppress the RFI. The carbon core wire
has better insulation, it carries the current more efficiently achieving a
better spark for the size of the core and this insulation suppresses RFI
(noise) which effects your electronics. Besides all the terminal ends can
be purchased where they are manufactured not to come off. Do they brake
down, yep, but all you have to do is change them out again. It happens on
all cars. But, I have only had one coil that I couldn't repair with new
wires and have it work.
The question was brought up as to how they are screwed into the barb
at the bottom of the coil connection area; It's simple, strip back the
insulation 3/4 inch exposing the carbon core and fold it up against the side
of the wire. Then just twist when you hit bottom, I also use a meter to
check connectivity between the two wires. (this is gone over in my article
on how to change them out)
Do dragsters and funny cars have solid wire plug wires, yes, but
none have radios in them either. And check out the size of these wires.
I offered a solution to a problem all Honda 600 coils will
eventually have. If you want to find some solid core wires to replace your
broken ones, go to the off road store.
Now I have to go back to what I originally said, comparing water out
the end of a hose, it's the same water, but the nozzle defines how and where
that water is going. Both wires use the same current from the coil, but the
carbon core wire does a better job of it over all. And, your car will run
better than it did, just because the wires are doing what they are supposed
to do.
> Sent: Thursday, January 12, 2006 8:07 AM
> Bill,
> with carbon which is acting like a choke. A choke is a device used to
> reduce the electrical interference (aka EMF).
> tear up a carbon or spiral wound alloy and carbon wire. Typically, those
> wires have a sharp pin stuck in their ends to work. if you mangle up the
> end on them, there could possibly be a connection problem. It's just
> another reason to stick with solid core wires.
> Bill) carbon or graphite core wire, then that's fine. That will perform in
> a manner similar to the solid core (stranded center) ignition wire. But in
> going to give better performance.
> the hottest and that is followed by the prolonged spark that completes
> the burn. A sparks length is determined by voltage not amperage. However,
> the ability to maintain the spark is dictated by available amperage, which
> by using resistor wires or any device that introduces resistance in series
> with the spark, will reduce to some degree, the available current
> (amperage).
> it heading towards a pissing match. You are by far much more of the Honda
> 600 expert than I am, even though I have rebuilt (in the late 70's)
> somewhere around 15 or 16 of them). I have been down the road of trying
> all sorts of things to get these cars to run stronger, and one of the
> conclusions I came to was that the solid core wires (again, the original
> wires are solid core) with no resistor plug connectors, but the solid
> connectors and new silicone boots, simply work better.
> advice. From all indications, his 600 runs better than ever. I for one am
> happy about whichever way he did it.
> Richard Morris
> Hi Murray;
> much easier to understand. Carbon Core wires will do the job better.
> spark plug wires.
> [ Behalf Of Murray
> Atkinson
> because
> to
> higher.
> produce
> the leads.
> around a car.
> last
> My AUS$0.02 worth.
> Murray.
> to
> interference.
LewetagK@...
> > Bill;
_lewetagk@...
_ ()
> > Ken
richard.morris@...
writes:
> > Bill,
> > opinion.
> silver
> > Richard Morris
> > [] On Behalf Of Bill
> Colford
> > Spark Plug wires;
> that
> > [ Behalf Of Richard
> > Marshall,
> will
> > onto.
> > Richard Morris
> > [] On Behalf Of Marshall
> > about the chain:
> separately
> and
> coils
> > are hotter.
> > OR
> plug
> chain:
> while
> the
> > chain is off.
> > wires.
> > Matt
> > Yahoo! Photos
> ( >m/*
> hotos/evt=38087/*
Re: TO Bill
Post by Lyle »
Richard;
Don't get me wrong, this is not a pissing match. It's about keeping
Honda 600's going down the road. 60's technology gave us many things, but
carbon core wire was not in use yet. The article is not trying to say Bill
is right or that Richard is wrong. It simply states that solid wire spark
plug wires are not as efficient as carbon core or the MAG WIRE they are
selling. I could have use an article from CARB, but it's to long and had to
many negative issues, or was it their agenda? Either way all Honda 600 Coils
can be rewired and carbon core is one alternative.
> Bill,
> (amperage).
> Richard Morris
> Hi Murray;
> spark plug wires.
> [ Behalf Of Murray
> Atkinson
> because
> to
> higher.
> produce
> the leads.
> around a car.
> last
> My AUS$0.02 worth.
> Murray.
> to
> interference.
LewetagK@...
> > Bill;
_lewetagk@...
_ ()
> > Ken
richard.morris@...
writes:
> > Bill,
> > opinion.
> silver
> > Richard Morris
> Colford
> > Spark Plug wires;
> that
> > [ Behalf Of Richard
> > Marshall,
> will
> > onto.
> > Richard Morris
> > about the chain:
> separately
> and
> coils
> > are hotter.
> > OR
> plug
> chain:
> while
> the
> > chain is off.
> > wires.
> > Matt
> > Yahoo! Photos
> ( >m/*
> hotos/evt=38087/*
