Hi Daily Driver;
If you go to the anzhonda600owners@yahoogroups.com in the text area there
is a fix for the breaker plate which may be part of your problem. There is
also an article on changing your cam chain that takes you through timing,
setting your points, adjusting the rocker arms and all the rest. What has
to happen is every part working in unison to achieve combustion in the
chamber at the right time. And just about everything can cause it to be off
the mark.
