this is for who may need axle seals. here's the contact # for the company
for replacement seals.{TCM Dichtomatik 1-XXX-XXX-XXXX} they'll give you a
contact # for a supplier near you. the original seal #'s 91201-551-005 r.
side and 91206-551-005 l. side 54mm i.d., 75mm o.d., 12mm thick can be
replaced by one [oil seal] 54mm i.d., 75mm o.d., 10mm thick just remember
to champher the sharp case edge before installing the new seals and
install them just flush with the case edge and they will get rid of the
drip! hope this helps everyone. Michael King [King Transmission Service
in Asheville N.C.]
