Re: [2cylinderhondas] My n600 - giving up the ghost?
dana
Post by dana »
Message
With your plugs jet black, it's getting way too much fuel. Does your fuel pump shut off with the key on (engine not running)? I should do a click or two and stop.
If it keeps going, the main needle and seat (the one the float moves) is leaking. And I would still have 2 fuel filters on it, back by the tank and one by the carb, both clear plastic. Are you sure you have the right plugs in it?
Mine had the wrong plugs in it when I bought the car.
I know your coil was mounted by the air cleaner when you got the car, so the next issue (to me) is a weak spark. When you put the new wires on, did you screw them into the coil? (you should, there are little screws in the holes in the coil that the wires screw onto). The plug wires, once screwed into the coil, cannot be pulled straight out. If you didn't screw them into position, there is a potential weak spark situation.
If the ignition points have become pitted, that can also be a source of weak spark.
Richard Morris
> 2cylinderhondas@yahoogroups.com [mailto:2cylinderhondas@yahoogroups.com] > On > Behalf Of > Matt Timion > Sent:
> Thursday, July 06, 2006 12:05
> Checked the vacuum advance. It was working fine.
> I also checked the
> fuel filter for clogs. I did discover that it was on backwards, but I found no > debris in the filter or line. I might replace the line from the pump to the > carburator this weekend.
> Spark plugs were jet black (running rich). I
> replaced them and it ran fine for a few minutes, and then started acting up > again.
> Now I need to check the timing. perhaps it jumped a
> tooth.
> Matt Timion
> From: Tad
> Clark
> Sent: Wednesday, July 05, 2006 10:52 AM
> Subject: Re: [2cylinderhondas]
> My vote is for the vacuum advance going
> out. Remove the points cover and verify that the advance is moving when you > change the throttle position. When the vacuum advance fails or is disconnected > exactly what you described happens.
> [Non-text portions of this
> message have been removed]
dana
Post by dana »
Message
Has Mike O'Connor confirmed he actually did some work on it? Dirty air filter wouldn't cause this. (try running it without the air filter. what happens then?)
Me and several other people have mentioned several diagnostic things you should do (several emails ago as well as currently). Have you tried any of them? If not, why are you wasting your time emailing rather than trying the various diagnostic ideas you have been give by several --experienced-- people? If you have actually taken time to try them, you would have found the problem by now. You have been given troubleshooting ideas on ignition, fuel, timing and vacuum.
None of the things we have suggested you check will take more than 5 minutes each.
Don't just post messages, get out and work on it.
If this seems harsh, then maybe I have made my point.
Richard Morris
> Sunday, July 09, 2006 1:06
> Thanks Dale...
> The carbs are kind of a mystery to me, so it's taking
> me a while to get the courage to read on how they work. I guess that's what I > get for being a "youngin." > It's very possible the air filter is dirty > and ready for replacement. I'm hoping nothing is wrong with the carb as the > previous owner said it was just rebuilt by Mike O'Connor before he sold it to > me.
> Matt Timion
> goinhm@...
> Sent: Sunday, July 09, 2006 10:30 AM
> Subject: Re: [2cylinderhondas] My
> Matt,
> You are driving me crazy! The
> car is screaming at you "I have a problem
> in my intake system." Don't
> bother checking your timing belt or vacuum
> advance or tire pressure. If
> you can replace the plugs and the problems go away
> for even 30 seconds,
> the only place you can have a problem is in how the
> air/fuel mixture gets
> delivered to the engine.
> You have noticed the plugs get black (and you
> should see the exhaust is
> black and sooty). You have a problem with the
> carburetor or the air
> cleaner. Check (or temporarily remove) the air
> filter. Clean the carb, check it
> float level, and verify the needle and
> seat are functioning properly. Make
> sure the gaskets and o-rings are good
> and in place.
> I never said anything about the plugs getting
> fouled again, but i did say it
> ran fine for a few minutes... maybe around
> the block twice.
> But I'm having a difficult time believing that the
> plugs would get fowled
> after a few minutes when it took a month for there
> to be a performance decline
> previously.
> Matt Timion
> Original Message -----
> From: steve
> _2cylinderhondas@ 2cylinderhon2cy_
> (mailto:
> Sent: Friday, July 07, 2006 2:55 PM
> thought you said you replaced the plugs and
> just long enough to foul the plugs again?
> From: Matt Timion
> (mailto:
> Sent: Friday, July 07, 2006 10:42 AM
> I'm unsure if that's the case. I replaced
> the plugs and hte problem
> persisted.
> Matt Timion
> From: steve
> (mailto:
> Sent: Friday, July 07, 2006 10:01 AM
> You can try to use a hotter plug thatll
> burn the carbon off the tip but that
> is just a crutch to your ratio
> problem. Its the plugs that are causing you
> to run bad, its the carb that
> is affecting the plugs.
> From: Matt Timion
> To: _2cylinderhondas@ 2cylinderhon2cy_
> (mailto:
> Sent: Wednesday, July 05, 2006 10:05 PM
> working fine.
> I also checked the fuel filter for clogs. I did discover
> that it was on
> backwards, but I found no debris in the filter or line. I
> from the pump to the carburator this
> weekend.
> Spark plugs were jet black (running rich). I replaced them and > it ran fine > for a few minutes, and then started acting up > again.
> tooth.
> Matt Timion
> From: Tad
> Clark
> (mailto:
> you change the throttle position. When
> disconnected exactly what you described happens.
> this message have been removed]
