new clutch
greggsydenstricker
new clutch
Post by greggsydenstricker »
i need a clutch for my 72 600 coupe, where cani get one. Thanks Gregg
amareto23
Re: new clutch
Post by amareto23 »
amareto23
Re: new clutch
Post by amareto23 »
amareto23
Re: new clutch
Post by amareto23 »
hi Greg, if you have a brake and clutch rebuilder in your area they might
can help. if not i use Clutch and Brake of Asheville XXX-XXX-XXXX and
talk to Roger. you can send it to him prepaid and he'll rebuild it and
send it back. hope this helps, Michael King
Mr. Gregg Sydenstricker
Re: new clutch
Post by Mr. Gregg Sydenstricker »
thank very much for clutch info Gregg
> michael w
> king
> Saturday, July 08, 2006 3:01
> Re: [anzhonda600owners] new
> clutch
> hi Greg, if you have a brake and clutch rebuilder in your area they > might > can help. if not i use Clutch and Brake of Asheville XXX-XXX-XXXX > and > talk to Roger. you can send it to him prepaid and he'll rebuild it > and > send it back. hope this helps, Michael King
Re: new clutch
Hi Gregg or Mike
There are several parts to a Honda 600 clutch just like all other vehicles.
However, normally all you need is the friction plate, an inner seal for the drum and do a bit of cleaning up.  Unless the diaphragm spring is broken, one or more of the three torque springs are broken.  If any of these are broken most rebuilders will not be able to help you.  I am including the two pages from the parts manual so you will see what I am talking about.
The drum and pressure plate can be smoothed out (cleaned up) with an 80 grit paper on your Die Grinder, a drill may not go fast enough.  Trying to have a shop do it will give you the same results, because they are not going to take the time to chuck it up in a lathe.  The two springs I am talking about are numbers 12 and 9 on the list.  If you are going to have the clutch disc rebuilt just tell them that it is the same size as an MG for the friction material.  They will not have a listing for a Honda 600.
> michael w
> king
> Saturday, July 08, 2006 12:56 PM
> new clutch
> i need a clutch for my 72 600 coupe, where cani get one. Thanks > Gregg
Re: new clutch
Bill I would very happy to find just a disc.Could you tell me a disc part number or what kind of car its out of.Most auto parts only sell kits.I do own a automatic trans shop.Just need to tell auto parts something....Thanks for all your help    Gregg
> billmyong@...
> kingtrans@...
> Anzhonda600owners
> Sunday, July 09, 2006 12:40
> RE: [anzhonda600owners] new
> clutch
> Hi
> Gregg or Mike
> like all other vehicles.  However, normally all you need is the friction > plate, an inner seal for the drum and do a bit of cleaning up.  Unless > the diaphragm spring is broken, one or more of the > three torque springs are broken.  If any of these are broken > most rebuilders will not be able to help you.  I am including the two > pages from the parts manual so you will see what I am talking about.  The > drum and pressure plate can be smoothed out (cleaned up) with an 80 grit paper > on your Die Grinder, a drill may not go fast enough.  Trying to have a > shop do it will give you the same results, because they are not going to take > the time to chuck it up in a lathe.  The two springs I am talking about > are numbers 12 and 9 on the list.  If you are going to have the clutch > disc rebuilt just tell them that it is the same size as an MG for the friction > material.  They will not have a listing for a Honda 600.
> > On Behalf Of
> > michael w
> > king
> > new clutch
> > i need a clutch for my 72 600 coupe, where cani get one. Thanks > > Gregg
infinkc
Re: new clutch
Post by infinkc »
i have a few extra disks/clutch assemblies, i will have to go see
how much meat are on them or if you want one for a core, if
interested send me an email.
Re: new clutch
HI my name is Gregg.Im interested in one of your clutch assm.PLease put together one assm. and please give me the price and could you ship it out.OR call meXXX-XXX-XXXX  Thanks
> infinkc
> Monday, July 10, 2006 4:44 PM
> [anzhonda600owners] Re: new
> clutch
> i have a few extra disks/clutch assemblies, i will have to go see > how > much meat are on them or if you want one for a core, if > interested send me > an email.
> "Mr. Gregg Sydenstricker"
> Bill I would very happy to find just a disc.Could you tell me a > disc part > number or what kind of car its out of.Most auto parts only > sell kits.I do > own a automatic trans shop.Just need to tell auto > parts > something... .Thanks for all your help Gregg > > ----- Original > Message ----- > > From: billmyong@.. .
> kingtrans@.. . ; Anzhonda600owners
> > Sent: Sunday, July 09, 2006
> 12:40 AM
> > Subject: RE: [anzhonda600owners] new clutch
> > Hi Gregg or Mike
> cleaning up.
> three
> rebuilders will not be able to help you. I am including the two > pages > from the parts manual so you will see what I am talking > about. The drum > and pressure plate can be smoothed out (cleaned up) > with an 80 grit paper > on your Die Grinder, a drill may not go fast > enough. Trying to have a shop > do it will give you the same results, > because they are not going to take > the time to chuck it up in a > lathe. The two springs I am talking about are > numbers 12 and 9 on > the list. If you are going to have the clutch disc > rebuilt just > tell them that it is the same size as an MG for the friction
> > -----Original
> Message-----
> ]On
> Behalf Of michael w king
> > Sent: Saturday, July 08, 2006 12:56
> Subject: Re: [anzhonda600owners] new clutch
> Thanks
> Gregg
