Re: [2cylinderhondas] Robin Kinkead? OIl filter
Honda 600 owenr;
    What you found in your removal of the oil filter could not have cause the oil not to go through the filter and into the engine.  I would look further for (as you put it) oil starvation.....
    Best guess is the oil pump.
> 2cylinderhondas@yahoogroups.com [mailto:2cylinderhondas@yahoogroups.com] > On > Behalf Of > enerdome > Sent:
> Tuesday, September 05, 2006 8:58
> Robin, are you still lurking out there? I tore Down Wanda the > Honda's > engine yesterday and found that the oil filter gasket was > jammed in between > the filter and the engine. looks like the engine > seized because of oil > starvation.. ..
