The big difference between the first series (or A series) is the transition from constant transmission with one over drive gear (4th) and the full synchro transmission with two over drive (3rd and 4th) gears. The engine numbers are significant to Honda 600's destined to the US as these engines were detuned from 45hp to 36hp.
> 2cylinderhondas@yahoogroups.com [mailto:2cylinderhondas@yahoogroups.com] > On > Behalf Of > howardsugarman@...
> Sunday, April 08, 2007
> 5:58 AM
> [2cylinderhondas] honda b-series engine
> Honda B-series engine are double over cam engine with
> V-tec. There are a
> few B-engine. the 1st. is the B16a
> which was on the del sol vtec si, this
> engine was on
> the delsol from 92-97 which has a horse power of about
> 160
> and it was OBD1. then there the b16b which came
> with in 1999-2000 honda
> civic si which produce about
> 160hp also but came in OBD2. earlier B series
> were the
> b17a and b17b which where in the 1989-1993 integra LS
> and GSR
> and uses OBD0. new b-series for integra are
> the b18b and b18C1 and B18C5.
> B18b came in the integra
> LS-GS 1994-2001 and produce about 140hp, then
> the
> b18C1 came in the 1994-2001 integra GSR which produce
> about 170hp,
> and there the b18c5 only come in red
> valve cover and produces about 195hp
> and only came in
> the integra Type-R only and were only produced in
> the
> integra only and very few were made. then the b-20,
> came all of the
> honda CRV, this engine is normally
> made for the franemstien setup v-tec.
> people would
> take the head of the GSR and mod to fit the B-20, with
> low
> compression piston is a great setup for turbo. if
> you were going to put
> anyone of these engine inside
> the 600 honda, good luck! the wide and the
> depth will
> not fit, the only engines that will probably fit the
> 600
> beside the original engine are, 3 cyclinders geo
> metro or the suzuki swift
> but with alot of mode work.
> most of these info are pretty accurate but if
> there is
> correction, please let me know. Thanks!
> --- Jamie lookn4u2return@ hotmail.com
> > Hey Tim
> > What is a honda b series
> engine?
> ____________ _________ _________ _________ _________ _________ _ > Be > a PS3 game guru.
> Get your game face on with the latest PS3 news and
> previews at Yahoo! Games.
> http://videogames. yahoo.com/ platform? platform= 120121
