Re: [2cylinderhondas] Coupe Window Regulators
Hi Miles;
    I have used successfully several times a nylon wheel for a typical patio door (bottom) roller.  The package can be found in most Home Depot stores and comes with the bolt to replace the pin.  Cut the top and bottom of the roller (so they are flat) and replace it.  The nylon works with or without grease.
> Monday, May 14, 2007 11:19
> I made a successful repair to Javier's window regulator on his coupe.
> One of the plastic squares was missing, so the window kept falling down
> inside the door. I used a section of 1/4" thick x 1" wide aluminum x 1"
> aprox. long. I had to shave the height down a bit to get it in the
> track, but it fits and works swell.
> I drilled out the original
> rivet then drilled and tapped the aluminum
> to 1/4-20, I cut a recess in
> one side so I could pein the bolt end over
> to trap it. I used a 1/4" hex
> bolt and 2 6mm washers to attain correct
> spacing. Sorry, no pics, it's
> back in the door.
