Re: [2cylinderhondas] Re: Piston rings
Hastings will make other sizes, but you have to order and it took almost 6 months to get .75 overs.  Another time I ordered .25 overs and received .50 over oil rings.  Miles is right but I like Grinding to fit the best, have your cylinders bored to match the piston (keep cylinders as straight as possible some shops like to widen them at the lower end).  Then when you receive your rings put them in your new cylinder bore and slide them up and down the cylinder to find the closest area.
Book calls for the top or compression ring to be .045 to .075 mm and the second ring and oil ring to be .015 to .045 mm.
    I have my bore one point five thousands over the piston size.  And while the pistons and cylinders are at the shop have them weigh the pistons to get them both the same weight.  All this helps when you want to reduce piston slap and make your engine to be as quite as possible.  I have had brand new pistons weigh in way different, and it all effects performance.
> Sunday, May 27, 2007 11:50
> Hastings doesn't have all 5 sizes available. Last time I checked they
> only had STD, .25mm & .50mm oversizes.
> The Honda 600 oil ring
> is an odd height (2.8mm) compared to other
> cars. The compression ring is
> hard chrome plated and is 2.5mm tall,
> The 2nd ring is regular cast iron
> and is also 2.5mm tall. The oil
> ring is 2.8mm tall.
> There is a
> couple models of Civic which have 74mm pistons. The oil
> ring is 3 pieces
> and is 3mm tall so you have to widen the slot in
> your piston (a machine
> shop does it) but you get 4 sets that way and
> you have spares. It's cheap
> for the Civic rings. My 1993 Geo Metro
> also had 74mm pistons, but I don't
> recall what the piston rings
> looked like, but the wrist pins were the
> correct diameter and were in
> the correct location, so if you didn't mind
> low performance (concave
> tops) it might run?
> Don't forget with the
> Hastings rings to fit them to your bores before
> installing them on the
> pistons. If the gaps are too tight the engine
> may seize, too wide and you
> will burn oil. I believe the correct gap
> is .008" to .012".
> Your
> original bore size is 74mm. First oversize would be 74.25mm, > then 74.50mm > etc up to 75mm. 75mm is the largest size ofered by > Honda. Sometimes you > can still see the numbers on the tops of the > original rings. On the left > side of the ring it will have an N or an > R. On the right side it will have > nothing or 25 or 50 or 75 or 100.
> If it has nothing it is Standard
> original size.
> Steven Michelsen
> > Hey,
> Hastings has an 800# now:
> > Toll Free: XXX-XXX-XXXX
> > From: "Steven Michelsen"
> Sent: Sunday, May 27, 2007 2:54 PM
> > Subject: Re: [2cylinderhondas]
> Piston rings
> > > This is what I know. Call to
> confirm.
> http://www.honda600 coupe.com/ Hastings_ rings_for_ Honda_600s. html
> > > Good luck,
> > > Steve
> www.honda600coupe. com
> > > ----- Original Message
> > > From: "easy_stuff_ sanchez"
> > Sent: Sunday, May 27, 2007 2:11 PM
> [2cylinderhondas] Piston rings
> > >> What
> is a good source for Piston rings ?
> > >> How do i
> know what size I need ?
> > >> What is the ring "
> Gap " supossed to measure ??
