Check the plug wires, they twist in like a Motorcycle's, also look at the end (where it fits over the spark plug) there should be a small wire that crosses the hole at the end. If this is missing or bent the plug may not be connecting.
All the other parts you mentioned must be working if it fires on the other cylinder as the Honda 600 fires both cylinders at the same time.
> 2cylinderhondas@yahoogroups.com [mailto:2cylinderhondas@yahoogroups.com] > On > Behalf Of > incompliable711 > Sent:
> Friday, December 28, 2007 4:18
> [2cylinderhondas] Misfire
> I just recently bought a 71 A600. It ran great when I picked it up in
> Oklahoma. I towed it back to Minnesota in the rain and snow and now it
> will only run on one cylinder. Well, it only idles on one cylinder.
> Once I get it above about 2500 RPM when the vaccum advance engages then
> the other cylinder kicks in. I checked/cleaned the points. I adjusted
> them to about .013" gap. I replaced the lead wire going from the
> points to the coil as it was deteriorating. I replaced the ground
> strap from the coil/chassis to the engine because it was trashed. But
> none of these things helped my problem at all. Any ideas?
