Battery is missing
geez_tech
Battery is missing
Post by geez_tech »
The owners manual says this has a 45ah battery, would this be a small
tractor (lawn and garden type) battery for these?
Is there a particular brand that fits/works best or should I just
measure the tray then go down to the local auto store and start
measuring?
Mike
Re: Battery is missing
Hi Mike,
    The batteries I have been using are the #51 and #51R.  I have been told some of the newer Honda vehicles are using this battery.  It is small enough to fit the tray and has the ratings necessary to work on the 600.
Both batteries will have the negative post at the front of the car.
The #51 allows the positive post to be nearest the fender while the #51R allows the positive post to be nearest the engine.  I believe the original batteries had the pos/neg posts near the fender.  I have used both batteries and which one you choose may be dictated by the length of your cables.
    I have purchased my batteries at Costco and Knecht's Auto Parts.
PS   I used to use the tractor batteries before finding the #51 battery.  The sedan offers more space to use an assortment of batteries but the coupe is more restrictive because of the way the front sheet metal narrows down and the slope of the hood.
In a message dated 3/11/2008 8:40:27 P.M. Pacific Daylight Time, tmspeer@... writes:
> The
> owners manual says this has a 45ah battery, would this be a small > tractor > (lawn and garden type) battery for these?
> measuring?
> Mike
It's Tax Time!
Get tips, forms and advice on AOL Money & Finance.
geez_tech
Post by geez_tech »
Thanks Dave,
Using a Honda battery would be good and look correct under the
hood, it just depends on what they run these days at the Dealer.
Otherwise I will go with the 51R as I dont like the terminals to be
close to any metal.
Mike
, goinhm@... wrote:
> Hi Mike,
been told
small enough
car. The #51
allows the
batteries had
which one
Parts.
battery.
the coupe is
down and
> tmspeer@... writes:
small
> measuring?
> Mike
> **************It's Tax Time! Get tips, forms, and advice on AOL
Money &
> Finance. (
http://money.aol.com/tax?NCID=aolprf00030000000001)
