Re: Need help
Alexander G. Penalosa
Re: Need help
Post by Alexander G. Penalosa »
My '72 AZ600 was starting and running a week ago and now I can't seem to make it start although itr cranks.  Have read from the email threads about similar problems which might concern clogged fuel liness or problems with the carburetor.  I don't have the faintest idea as I am not even an amateur mechanic.  I would greatly appreciate any recommendation If you or you know of someone within a radius of 100 miles from Concord, CA (so I can have the car towed to the location) who could fix this problem and an a[[rpximate of how much it would cost.
Alex
Re: Need help
I would like to take this opportunity to thank Miles Chappel (www.600miles.com) for doing a great job of coming over to my place to tune and correct the timing of my AZ600.  My 600 is now starting right up and the engine runs smoother.  Thanks a lot Miles and I am sure there are a lot of other folks like me who have benefited well from your expertise and services.  I would also like to thank everybody who has extended their expertise and experience and it sure is a great thing to be a member of this group.
Alex From:
Alexander G. Penalosa To:
Monday, December 29, 2008 11:47:24 AM Subject:
[anzhonda600owners] Re: Need help
Alex
Kevin Lister
Re: Need help
Post by Kevin Lister »
Yep! My '72 Sedan would likely not be running if Miles hadn't come over and pointed out several subtle problems, which he fixed.
kev
Mon, 1/5/09, Alexander G. Penalosa
Subject: Re: [anzhonda600owners] Re: Need help
Date: Monday, January 5, 2009, 10:33 AM
I would like to take this opportunity to thank Miles Chappel (www.600miles. com) for doing a great job of coming over to my place to tune and correct the timing of my AZ600.  My 600 is now starting right up and the engine runs smoother.  Thanks a lot Miles and I am sure there are a lot of other folks like me who have benefited well from your expertise and services.  I would also like to thank everybody who has extended their expertise and experience and it sure is a great thing to be a member of this group.
Alex
anzhonda600owners@ yahoogroups. com
Alex
James Hawkins
Re: Need help
Post by James Hawkins »
Kevin:   Glad you have it going.
Finally mine is running real good.
 Coming home from another town the other day I was running out of oxygen and had about 35 miles to go with just a tad of o2.  Well I got into the little car more than I ever had.  I came in at 70 mph and still had more pedal.  Ran like a sewing machine. Lacked about 4 miles making it but was ok
Anyone know how fast just a plain daily driver will run? Kinda curious
but not enough to find out.
> Kevin Lister
> Monday, January 12, 2009 6:19
> help
> Yep! My '72 Sedan would likely not be running if Miles hadn't come > over and pointed out several subtle problems, which he fixed.
> kev
> --- On
> alex_penalosa@ yahoo.com
> > Alexander G. Penalosa > alex_penalosa@ yahoo.com
> > Date:
> > I would like to take this opportunity to thank Miles Chappel > > (www.600miles. com) for doing a great job of coming over to my place > > to tune and correct the timing of my AZ600.  My 600 is now > > starting right up and the engine runs smoother.  Thanks a lot > > Miles and I am sure there are a lot of other folks like me who have > > benefited well from your expertise and services.  I would also > > like to thank everybody who has extended their expertise and > > experience and it sure is a great thing to be a member of this > > group.
> > Alex
> > Alexander G.
> > Penalosa
> > anzhonda600owners@
> > yahoogroups. com
> > 11:47:24 AM
> > My '72 AZ600 was starting and running a week ago and now I can't > > seem to make it start although itr cranks.  Have read from > > the email threads about similar problems which might > > concern clogged fuel liness or problems with the > > carburetor.  I don't have the faintest idea as I am not even an > > amateur mechanic.  I would greatly appreciate any recommendation > > If you or you know of someone within a radius of 100 miles from > > Concord, CA (so I can have the car towed to the location) who could > > fix this problem and an a[[rpximate of how much it would cost.
> > Thanks,
> > Alex
> Checked by AVG -
> http://www.avg.com
> Version: 8.0.176 / Virus Database: 270.10.6/1888 -
> Release Date: 1/12/2009 7:04 AM
woodwizard
75 MPH
Post by woodwizard »
....that's where the shift indicator range ends and I let up.
Had my sedan on track at Charlotte Motor Speedway back in November. With no speed limit (or hills), and 2 extra passengers, she still ran 75mph!
....not sure how much pedal was left - I was too busy holding on to notice... ;)
The excursion was all documented and I'm working on the video for Utube - of which, you guys will be the first to know when it's posted.
Now then...... do I hear 80?
Mon, 1/12/09, James Hawkins
> From: James Hawkins
> Date: Monday, January 12, 2009, 8:08 PM
>    Kevin:   Glad you have it going.  Finally mine is running real good.
> > Kevin Lister
> > Monday, January 12, 2009 6:19 PM
> > kev
> > --- On
> > > From: Alexander G. Penalosa > > alex_penalosa@ yahoo.com
> > > Alex
> > > Sent:
> > > Thanks,
> > > Alex
> > Checked by AVG - http://www.avg. com
> > Version: 8.0.176 / Virus Database: 270.10.6/1888 - Release Date: 1/12/2009 7:04 AM
Frank Camillieri
Re: 75 MPH
Post by Frank Camillieri »
My friend's coupe showed 100mph on the speedo down a steep hill with 3 aboard. We ran our cars at an indicated 72mph in the same lane passing cars on the interstate. You get funny looks when you do that. This was back in the 70's.
On Tue, Jan 13, 2009 at 8:14 AM, WoodWizard 33
> --- On
> cotteni@...
> > From: James Hawkins > cotteni@...
> > > Kevin Lister
> > > Sent:
> > > kev
> > > --- On
> > > wrote:
> > > > From: Alexander G. Penalosa > > > alex_penalosa@ yahoo.com
> > > > To:
> > > > Alex
> > > > From:
> > > > Alexander G. Penalosa > > > yahoo.com
> > > > To:
> > > > Sent:
> > > > Subject:
> > > > Thanks,
> > > > Alex
> > > Checked by AVG -
> > > http://www.avg
> > > . com
isettakurt
Re: 75 MPH
Post by isettakurt »
I have larger 13" diameter Mazda wheels on my Z, and even though the
speedometer is less trusted than Bush's foreign policy plan, I think
I was getting at least 80 mph. The tachometer was pushing a little
past redline, and I believe the tach more than I do the speedometer,
which indicated about 85 mph. Definitely wouldn't want to make a
habit of pushing the car that hard, but sometimes you just have to
show that Ferrari in the fast lane that he's holding up traffic.
Dave Kornberg
JN
Re: 75 MPH
Post by JN »
And now it's a parts car because you people don't respect that TINY little engine.  If you want to go that fast, get a v8.
Tue, 1/13/09, Frank Camillieri
> From: Frank Camillieri
> Subject: Re: [anzhonda600owners] 75 MPH
> Date: Tuesday, January 13, 2009, 8:49 AM
> woodwizard33@ yahoo.com
> > --- On
> > > cotteni@brazosnet. com
> > > From: James Hawkins > > cotteni@brazosnet. com
> > > > From:
> > > > Kevin Lister
> > > > To:
> > > > Sent:
> > > > Subject:
> > > > kev
> > > > --- On
> > > > wrote:
> > > > > From: Alexander G. Penalosa > > > > alex_penalosa@ yahoo.com
> > > > > To:
> > > > > Alex
> > > > > From:
> > > > > Alexander G. Penalosa > > > > yahoo.com
> > > > > To:
> > > > > Sent:
> > > > > Subject:
> > > > > Thanks,
> > > > > Alex
> > > > Checked by AVG -
> > > > http://www.avg
> > > > . com
Kevin Lister
Re: Need help
I drive my sedan every day as long as it's not raining! I don't drive it in the rain as I want it to last as long as possible. The rain just pours right into the engine compartment and isn't good for the wiring or anything else!
You can check out pic's of my sedan on the group.
kev
Date: Monday, January 12, 2009, 5:08 PM
> Kevin Lister
> kev
> --- On
> > From: Alexander G. Penalosa > alex_penalosa@ yahoo.com
> > Alex
> > Thanks,
> > Alex
Frank Camillieri
Re: 75 MPH
Back then you could buy them for $500 or less. I still have some parts.
On Tue, Jan 13, 2009 at 12:44 PM, JN
> --- On
> frank@...
> > From: Frank Camillieri > frank@...
