Column mounted ignitions switch removal.
Hi folks! I have a 71n600 with a column mounted igintion switch that I need to remove to have a key made. Anyone have any tips? It looks as if the factory used screws with break away heads to install.
Re: Column mounted ignitions switch removal.
Paul, take the steering column out. It's not that hard to do. Some people have busted the steering wheel lock and mount a switch in the dash, but that's the easy way out.
Bruce D.
Santa Clara CA From:
paul tate To:
Tuesday, February 24, 2009 4:08:31 PM Subject:
[anzhonda600owners] Column mounted ignitions switch removal.
Bruce D.
paul tate To:
I think the steering lock is already busted. No key but the steering wheel turns freely.
Tue, 2/24/09, Bruce Dewing
> From: Bruce Dewing
> Subject: Re: [anzhonda600owners] Column mounted ignitions switch removal.
> Date: Tuesday, February 24, 2009, 8:58 PM
> Paul,
> Bruce D.
> Santa Clara CA
> paul tate
Paul;
I have a lock assembly with key ready to install. Contact me off line.
> paul
> tate
> Tuesday, February 24, 2009 4:09 PM
> [anzhonda600owners]
> igintion switch that I need to remove to have a key made. Anyone > have any tips? It looks as if the factory used screws with break > away heads to install.
tommyjayallen
I have removed a lot of these by making a slot in the bolt with a small chissel. The bolts are not very tight, and are loosened by the hammering.
> From: Bruce Dewing
> Date: Tuesday, February 24, 2009, 6:58 PM
> Paul,
> Bruce D.
> Santa Clara CA
> paul tate
