removing gas tank
kevin.gailey
removing gas tank
Post by kevin.gailey »
I am in the process of removing gas tank and cleaning and sealing. I
cannot get off bolts from top back of tank, the nuts spin free and they are not accessible through the three small slits. Screw driver didn't work, any suggestions?
Kevin Gailey
Tom Feick
Re: removing gas tank
Post by Tom Feick »
Kevin,
Are you talking about the 3 screws that hold the sending unit in place?
Wed, 7/22/09, kevin.gailey
> From: kevin.gailey
> Subject: [anzhonda600owners] removing gas tank
> Date: Wednesday, July 22, 2009, 12:36 AM
> Kevin Gailey
Kevin Gailey
Post by Kevin Gailey »
I am talking about the bolts that hold the tank on the body.  The tree screws closest to the bumper. They are supposed to not move, but they move freely.
Tom Feick To:
Wednesday, July 22, 2009 8:56:14 AM Subject:
Re:
Kevin, Are you talking about the 3 screws that hold the sending unit in place?
> From: kevin.gailey
> Kevin Gailey
Tom Feick
Post by Tom Feick »
I have the Sedan which has 2 bolts in the back (one on each corner kind of). Mine came off pretty easily - sorry I can't help
Wed, 7/22/09, Kevin Gailey
> From: Kevin Gailey
> Subject: Re: [anzhonda600owners] removing gas tank
> Date: Wednesday, July 22, 2009, 2:24 PM
> Tom Feick
> Kevin,
> --- On
> > From: kevin.gailey
> > Kevin Gailey
Kevin;
It sounds like your removing the tank on an early Coupe, correct?
Are you unscrewing them from the access points in the spare tire area?
If that is where you are, then jam a screw driver against the bolt head and drill it out.  After the tank is out get some clip on nuts like the coupe has built after 1 Jan 72.   You will have to grind the old nuts off (small spot welds) to make the surface smooth.   It should go back in easy.
> Kevin
> Gailey
> Wednesday, July 22, 2009 11:24 AM
> removing gas tank
> I am talking about the bolts that hold the tank on the body.  The > tree screws closest to the bumper. They are supposed to not move, but they > move freely.
> Tom Feick
> Kevin,
> Are you talking about the 3 screws that hold the sending unit in > place?
> --- On
> yahoo.com>
> > kevin.gailey
> > yahoogroups. com
> > I
> > cannot get off bolts from top back of tank, the nuts spin free > > and they are not accessible through the three small slits. Screw > > driver didn't work, any suggestions?
> > Kevin
> > Gailey
Robert Goodrich
Post by Robert Goodrich »
did you ever work and live in San Diego?
Thu, 7/23/09, billmyong@...
Subject: RE: [anzhonda600owners] removing gas tank
Date: Thursday, July 23, 2009, 12:11 AM
Kevin;
> anzhonda600owners@ yahoogroups. com [mailto:anzhonda600 owners@yahoogrou ps.com] > On Behalf Of > Kevin Gailey > Sent:
> Tom Feick
> Kevin,
> --- On
> > From: kevin..gailey
> > I am in the process of removing gas tank and cleaning and sealing. I > > cannot get off bolts from top back of tank, the nuts spin free and they are not accessible through the three small slits. Screw driver didn't work, any suggestions?
> > Kevin Gailey
Kevin;
Yes, and I still do.
> Robert
> Goodrich
> Thursday, July 23, 2009 5:04 AM
> removing gas tank
> --- On
> Thu,
> 7/23/09, billmyong@earthlink .net
> > Subject: RE:
> > 23, 2009, 12:11 AM
> > Kevin;
> > If that is where you are, then jam a screw driver against the > > bolt head and drill it out.  After the tank is out get some clip > > on nuts like the coupe has built after 1 Jan 72.   You will > > have to grind the old nuts off (small spot welds) to make the surface > > smooth.   It should go back in easy.
> > > anzhonda600owners@
> > > yahoogroups. com [mailto:anzhonda600 owners@yahoogrou ps.com] > > > On > > > Behalf Of > > > Kevin Gailey > > > Sent:
> > > 11:24 AM
> > > com
> > > tank
> > > I am talking about the bolts that hold the tank on the > > > body.  The tree screws closest to the bumper. They are supposed > > > to not move, but they move freely.
> > > Tom Feick
> > > anzhonda600owners@
> > > yahoogroups. com
> > > Sent:
> > > 8:56:14 AM
> > > tank
> > > Kevin,
> > > Are you talking about the 3 screws that hold the sending > > > unit in place?
> > > --- On
> > > wrote:
> > > > From:
> > > > kevin..gailey > > > > Subject:
> > > > [anzhonda600owners] removing gas tank > > > > To:
> > > > anzhonda600owners@ yahoogroups. com > > > > Date: Wednesday, July > > > > 22, 2009, 12:36 AM
> > > > I am in the process of removing gas tank and cleaning > > > > and sealing. I > > > > cannot get off bolts from top back of > > > > tank, the nuts spin free and they are not accessible through > > > > the three small slits. Screw driver didn't work, any > > > > suggestions?
> > > > Kevin
> > > > Gailey
