I just tried Civic rear brake cylinders on my 600 Coupe and they fit!
The Civic is the same part R/L.
The only difference I can see is the 600 has a bleeder screw missing on the right one, they run 2 lines instead.
So if we use a "T" fitting on the rear axle like most cars do, then we can use the Civic parts.
Anybody confirm this info?
Rear brake cylinders
Re: Rear brake cylinders
I did that on mine. Civic Cylinders and ran line into a tee to both cylinders.
lyletrudell To:
Sun, August 15, 2010 7:15:09 PM Subject:
[anzhonda600owners] Rear brake cylinders
lyletrudell To:
Brad, good the parts I bought can be used!
Will have to see what metric "T" fitting will work, do you remember?
Hey, Brad send the info to Steve, future Honda owners will appreciate it.
> From: lyletrudell
> Sent: Sun, August 15, 2010 7:15:09 PM
> Subject: [anzhonda600owners] Rear brake cylinders
> the Civic parts.
> Lyle
I actually don't remember everything,it has been a few years since I did it. But I do remember using 73 Civic cylinders and having to do some brake line fabrication with a tee.
lyletrudell To:
Sun, August 15, 2010 7:44:01 PM Subject:
[anzhonda600owners] Re: Rear brake cylinders
lyletrudell To:
> From: lyletrudell
> the Civic parts.
> Lyle
