Wheel upgrade?
jeffanson2005
Wheel upgrade?
I've been restoring my 72 coupe and just had it painted. Now I want to replace the factory 10" wheels. I found that these are 4x110? Correct. Well I searched and found wheels I like. Ebay item# 310237241422. Can anyone advise me if they will fit with low profile tires and is the offset close enough to work. I'm primarily using for shows and dont plan on driving any more than 50 miles before I decide to sell it. Thanks to anyone who would like to advise.
If these are a bad idea, then what about wheel adaptors and 13" or 14" wheels to fit. I'd like to know if anyone had success and is happy with their choice.
Jeff
Miami,
72 Coupe
Jeff
Miami,
72 Coupe
Tran Nguyen
Re: Wheel upgrade?
15" are way to big for the coupe, makes the car look retarted...atleast go with 13" even too big in my opinion..
or go on minimania and look for a 10" minilite.
To: anzhonda600owners@yahoogroups.com From: jeff@...
Date: Mon, 23 Aug 2010 19:47:29 +0000 Subject: [anzhonda600owners] Wheel upgrade?
Jeff
Miami,
72 Coupe
Jeff
Miami,
72 Coupe
Re: Wheel upgrade?
Way to big. However there is one near me that is running either 13" or 15" with low profile tires,but the fenders have been flared out to fit. You need to consider tire runout,or circumference of the tire. Any change in this will greatly affect final drive gear ratio,and too much circumference,the car won't get out of its own way. Measure the circumference of your stock tire and compare to what you want to try to put on. You don't want any more than a couple of inches difference.
jeffanson2005 To:
Mon, August 23, 2010 2:47:29 PM Subject:
Jeff
Miami,
72 Coupe
jeffanson2005 To:
Jeff
Miami,
72 Coupe
Sir Herman
Re: Wheel upgrade?
The 15 wheels are too big for that application, mate. Im a bit bias, as Ive always sport 10 for my MK1 mini cooper, shown in the attached photo. The white mini has the 10" minilite wheels and the red clubman has 13" wheels. If the offset of the Honda 600 is the same as the minis, Id definitely go with the minilite wheels, minimania sells. See link:
http://www.minimania.com/web/SUBTYPE/Se ... entory.cfm
All the best
Herman
All the best
Herman
Re: Wheel upgrade?
My 600 Sedan has stock rims but one of my friends has a set of Alu. ATV wheels on his Sedan with DOT approved Golf Cart tires. Most of the offset on his wheels are to the outside. I've rode around town in his sedan and it seems to drive and ride fine but he said it's a little spooky on the highway, not sure if that the nature of the car or if the tires and wheels have something to do with it..
Someone brought up a good point about safety and strength of ATV wheels as the N600's are heavier than an ATV especially with a couple of size-able people in the car.
Mon, 8/23/10, Tran Nguyen
Subject: RE: [
anzhonda
Date: Monday, August 23, 2010, 3:03 PM
Jeff
Miami,
72 Coupe
Re: Wheel upgrade?
My coupe has 10"x 7" Aluminum wheels designed for Formula 500 race cars or Modified Midget race car, as I figured if they are good enough for a 1000 lb race car tat can go 100 mph sideways it would be good enough for my coupe. I am running Hoosier tires and also have a set of Goodyear slicks for Autocross.
paul tate To:
Mon, August 23, 2010 3:44:53 PM Subject:
RE: [anzhonda600owners] Wheel upgrade?
paul tate To:
Subject: RE: [
anzhonda
Jeff
Miami,
72 Coupe
Re: Wheel upgrade?
funny thing that the wheel subject just came up today. i just got my 10" Cosmic wheel back from the wheel guy. posted pic in the photo section
most all 4x110 wheels that will you find online are for the first Gen RX-7 which is rear wheel drive and they will bolt on no problem but stick out. the other problem is once you get them on you can't really find a tire that will give you a total roll out diameter anywhere close to stock so your gearing and speedo will be all out of the norm. here is a link to some 600's with 13" RX-7 wheels http://japanesenostalgiccar.com/forum/v ... +600+wheel
> Jeff
> Miami,
> 72 Coupe
twincarb600
Re: Wheel upgrade?
Who did you have restore your wheels? I have some but need to be cleaned up and polished but no time to get done.
http://japanesenostalgiccar.com/forum/v ... rt=0&postd\
> ays=0&postorder=asc&highlight=honda+600+wheel
> days=0&postorder=asc&highlight=honda+600+wheel>
, "jeffanson2005"
> their choice.
> > Jeff
> > Miami,
> > 72 Coupe
Re: Wheel upgrade?
I had alloy wheel repair specialist of arizona do mine (602)256-AWRS. My wheels were badly salt pitted and couldn't be polished out so they did a machined finish and it looks great. If you get close enough you can see porosity dots but im not building show car and happy with the way they came out.
Sent: Tuesday, August 24, 2010 9:28 PM
Subject: [anzhonda600owners] Re: Wheel upgrade?
[The entire original message is not included]--- In
> funny thing that the wheel subject just came up today. i just got my 10" > Cosmic wheel back from the wheel guy. posted pic in the photo section
> most all 4x110 wheels that will you find online are for the first Gen > RX-7 which is rear wheel drive and they will bolt on no problem but > stick out. the other problem is once you get them on you can't really > find a tire that will give you a total roll out diameter anywhere close > to stock so your gearing and speedo will be all out of the norm. here is > a link to some 600's with 13" RX-7 wheels
http://japanesenostalgiccar.com/forum/v ... rt=0&postd\ > ays=0&postorder=asc&highlight=honda+600+wheel > days=0&postorder=asc&highlight=honda+600+wheel>
, "jeffanson2
