> 2cylinderhondas@yahoogroups.com [mailto:2cylinderhondas@yahoogroups.com] > On > Behalf Of > lyletrudell > Sent:
> Saturday, February 26, 2011 7:11
> [2cylinderhondas] Re: Dash lights
> Dont forget to clean the lens when you have the gauge out.
> Remove the 4
> small phylips screws that hold the spring clips in.
> Pull the plastic face
> off and clean up.
> Sand/polish the spring clips and
> grease.
> Lyle
> "lyletrudell" wrote:
> > I have my dash
> out right now. Like Miles said, they come out the front. The problem is the > spring clips that hold the gauge in gets surface rust on them, making it hard > to remove. The clips have a raised bump on them to keep the gauge tight. You > could take 1/8 x 1/2 flat stock from Home depot, grind an angle on it and bend > to make a little pry bar, make 2. Wrap a little tape around the part that > touches the dash. Put some grease on the clips when you put them back.
> Good luck.
> > Lyle
> "feltonminicycle" wrote:
> > > The
> gauges pry out from the front. I use a small brad remover or a screwdriver.
> Care should be taken to not gouge the dash or sides of gauges.
> > > Miles
> In
> "nicholas_riopelle2001" wrote:
> > > > Can someone tell me how to remove the speedo, and idiot > light cluster > > > > so that I can put in a brighter bulb? I can > barely see the speedo > > > > numbers at night. All help is > appreciated.
