Name that Honda Bracket
Post by Lyle »
OK, I have a pile of (11) brackets and things, not sure if they are all from a 600 Coupe. I want to match up the photo to the part ref #.
This will probably be easy for the old time Honda folks.
See picture in the photo section.
#1 is upper left, #11 is bottom right.
This is my best guess.
#1 Cooling Fan, Clamp, Hot air duct. Ref#3
#2 No clue, it had a clear coating on it.
#3 Instruments, Clamp, tach cable. Ref#15
#4 Cooling Fan, Clamp, clutch cable. Ref#21
#5 Engine Shroud, Clamp, High tension cord. Ref#1
#6 No clue
#7 Vacuum Booster, Bracket Check valve. Ref#16
#8 Instruments, Guide, Speedometer cable. Ref#23
#8 Pedals, Guide, speedometer cable. Ref#19
#9 No clue
#10 Spare Tire, Stopper, Tire Lid. Ref#10
#11 Car Heater, Clamp, Heater duct B. Ref#3
I am missing and need:
Car Heater, Guide, Clutch wire. Ref#7
Cooling Fan, Clamp, Hot air duct. Ref#2
Pedals, Guide, Clutch wire. Ref#17
Thanks
