corrected valve clearance.
A Big thanks to Kevin for not only telling my valve lash was adjustable, but also for telling me how to do it. I should have read the manual more when I reassembled my engine.
My valve clearance was way too big.
After adjusting them the valves, the tapping sound was totally gone, and my engine has much more power. It's like I added a cylinder.
Just curious: What clearance do most of you like to use on your valves? I went with 0.008" on all valves.
thanks again,
Mike.
thanks again,
Mike.
Re: corrected valve clearance.
Hey Mike,
The book says .004". See the bottom half of this page.
http://www.honda600coupe.com/Adjusting_ ... ances.html
> Mega
> Wednesday, April 06, 2011 5:19
> [anzhonda600owners] corrected
> valve clearance.
> A Big thanks to Kevin for not only telling my valve lash was adjustable, > but also for telling me how to do it. I should have read the manual more when > I reassembled my engine.
> big.
> After adjusting them the valves, the tapping sound was totally > gone, and my engine has much more power. It's like I added a > cylinder.
> Just curious: What clearance do most of you like to use on > your valves? I went with 0.008" on all valves.
> thanks
> again,
> Mike.
How to? I set it with the .003 and .004 feeler gauges ( kind of a go/no go system) this way you don't get it to tight. I set it with the .004 and check it with the .003. If the .003 gauge does not go but the .004 does, then it is set properly.
> Steven
> Michelsen
> Wednesday, April 06, 2011 2:29 PM
> Re: [anzhonda600owners]
> Hey Mike,
> this page.
> Steve
> > Mega
> > PM
> > valve clearance.
> > A Big thanks to Kevin for not only telling my valve lash was adjustable, > > but also for telling me how to do it. I should have read the manual more > > when I reassembled my engine.
> > big.
> > After adjusting them the valves, the tapping sound was totally > > gone, and my engine has much more power. It's like I added a > > cylinder.
> > Just curious: What clearance do most of you like to use on > > your valves? I went with 0.008" on all valves.
> > thanks
> > again,
> > Mike.
blake neilson
Don't you mean that a .004 should go and a .005 should not?
I caught that too. It had me thinking for a second.
blake neilson To:
Thu, April 7, 2011 7:40:14 AM Subject:
Re: [anzhonda600owners] corrected valve clearance.
blake neilson To:
Lets take a close look at what is being done.
The optimum setting is .003. The .004 to .005 is not the best setting when a situation that is caused by the rocker to cam rolling over and creating a gap at the rear of the cam lobe beats the center of the rocker arm face. The timing necessary to reduce the clearance as in Paragraph 7 in the Coupe supplement, page 41, says this. .004 to .005 is to loose causing poor performance. Have you noticed that there is a indentation on the center of the rocker arm face? That condition is because of a loose adjustment. Or better yet, have you noticed that it is hard to keep an adjustment because a previous owner put to much torque on the rocker arm bolt causing a dimple in the rocker arm shaft. If you don't figure out how to adjust the rockers to the recommended .003, then you will have rocker arm slap. Causing the indentation at the center of the rocker arm face
.003 is the setting as stated in the Sedan shop manual page 2-4 under normal valve clearance.
> brad
> fenn
> Thursday, April 07, 2011 5:47 AM
> blake neilson
> clearance.
> "billmyong@..."
> Thu, April 7, 2011 2:27:34
> RE:
> clearance.
> How
> to? I set it with the .003 and .004 feeler gauges ( kind of a > go/no go system) this way you don't get it to tight. I set it with > the .004 and check it with the .003. If the .003 gauge does not go but > the .004 does, then it is set properly.
> > On Behalf Of
> > Steven
> > Michelsen
> > Hey Mike,
> > of this page.
> > Steve
> > > Mega
> > > Sent:
> > > PM
> > > [anzhonda600owners]
> > > A Big thanks to Kevin for not only telling my valve lash was > > > adjustable, but also for telling me how to do it. I should have read the > > > manual more when I reassembled my engine.
> > > way too big.
> > > After adjusting them the valves, the tapping sound was > > > totally gone, and my engine has much more power. It's like I added a > > > cylinder.
> > > Just curious: What clearance do most of you like to use > > > on your valves? I went with 0.008" on all valves.
> > > thanks
> > > again,
> > > Mike.
blake neilson
Regardless of what the optimal spec is, .003 or .004, I couldn't reconcile the following statement pasted from an earlier reply:
"If the .003 gauge does not go but the .004 does, then it is set properly."
In other words, if a .004 is a go how could a .003 (a thinner feeler gauge) NOT go? I will happily accept .003 as optimal but the go/no go method described is backwards. If a .004 is a go then anything less, .003, .002, .0015 would also be a go.
The reading is supposed to be .003 not .004. So you have it correct, it must have been late.
> blake
> neilson
> Wednesday, April 13, 2011 9:13 PM
> Regardless of what the optimal spec is, .003 or .004, I couldn't > reconcile the following statement pasted from an earlier reply:
> In other words, if a .004 is a go how could a .003 (a thinner feeler > gauge) > NOT > go? I will > happily accept .003 as optimal but the go/no go method described is backwards.
> If a .004 is a go then anything less, .003, .002, .0015 would also be a > go.
> "billmyong@..."
> Thu, April 7, 2011 8:07:59
> RE:
> clearance.
> Lets
> The
> optimum setting is .003. The .004 to .005 is not the best setting > when a situation that is caused by the rocker to cam rolling over and > creating a gap at the rear of the cam lobe beats the center of the rocker arm > face. The timing necessary to reduce the clearance as in Paragraph > 7 in the Coupe supplement, page 41, says this. .004 to .005 is to loose > causing poor performance. Have you noticed that there is > a indentation on the center of the rocker arm face? That condition > is because of a loose adjustment. Or better yet, have you noticed that > it is hard to keep an adjustment because a previous owner put to much torque > on the rocker arm bolt causing a dimple in the rocker arm shaft. If you > don't figure out how to adjust the rockers to the recommended .003, then you > will have rocker arm slap. Causing the indentation at the center of the > rocker arm face
> .003
> is the setting as stated in the Sedan shop manual page 2-4 under normal valve > clearance.
> > On Behalf Of
> > brad
> > fenn
> > blake neilson
> > AM
> > Re:
> > clearance.
> > "billmyong@..."
> > AM
> > RE:
> > clearance.
> > feeler gauges ( kind of a go/no go system) this way you don't get it to > > tight. I set it with the .004 and check it with the .003. If the > > .003 gauge does not go but the .004 does, then it is set properly.
> > > On Behalf Of
> > > Steven
> > > Michelsen
> > > Sent:
> > > Re:
> > > clearance.
> > > Hey Mike,
> > > half of this page.
> > > Steve
> > > > From:
> > > > Mega
> > > > To:
> > > > Sent:
> > > > 5:19 PM
> > > > Subject:
> > > > [anzhonda600owners]
> > > > A Big thanks to Kevin for not only telling my valve lash was > > > > adjustable, but also for telling me how to do it. I should have read the > > > > manual more when I reassembled my engine.
> > > > way too big.
> > > > was totally gone, and my engine has much more power. It's like I added a > > > > cylinder.
> > > > Just curious: What clearance do most of you like to use > > > > on your valves? I went with 0.008" on all valves.
> > > > thanks
> > > > again,
> > > > Mike.
blake neilson
Just trying to clarify the point. And I agree, Bill's advice over the years via this group has been excellent, so I had no doubt he was capable of setting the clearance correctly. Yet we do have some members who are getting their feet wet in the maintenance/repair side of the hobby so I wanted to eliminate any confusion. I was there once myself at the tender age of 17 when I bought my 600 new. It's all good.
Blake From:
Lyle To:
Thu, April 14, 2011 1:33:38 AM Subject:
[anzhonda600owners] Re: corrected valve clearance.
Yep, your right, it was backwards. But, Bill has set so many valve clearances over the years that he probably got burned out from posting the same info over and over again for 30 years. Like all of us, he does this to help the Honda 600 folks.....for free!
Lighten up!
I made a mistake once also, but I reconciled it!
I hope my spelling is correct.
Blake From:
Lyle To:
Lighten up!
> In other words, if a .004 is a go how could a .003 (a thinner feeler gauge)�
> NOT� go?� I will happily accept .003 as optimal but the go/no go method
> would also be a go.
> From: "billmyong@..."
> Sent: Thu, April 7, 2011 8:07:59 PM
> Subject: RE: [anzhonda600owners] corrected valve clearance.
> The optimum setting is .003.� The .004 to .005 is not the best setting when� a
> the rear of the cam lobe beats the center of the rocker arm face.� � The timing
> page 41, says this.� .004 to .005 is to loose causing poor performance.� Have
> you noticed that there is a� indentation on the center of the rocker arm face?�
> That condition is because of a loose adjustment.� Or better yet, have you
> much torque on the rocker arm bolt causing a dimple in the rocker arm shaft.� If
> will have rocker arm slap.� Causing the indentation at the center of the rocker
> arm face
> valve clearance.
> >From:
> >[mailto:
]On Behalf Of brad fenn
> >Sent: Thursday, April 07, 2011 5:47 AM
> >To:
> >Subject: Re: [anzhonda600owners] corrected valve clearance.
> From: blake neilson
> >To:
> >Sent: Thu, April 7, 2011 7:40:14 AM
> >To:
> >Sent: Thu, April 7, 2011 2:27:34 AM
> >How to? � I set it with the� .003 and .004 feeler gauges ( kind of a go/no go
> >system)� this way you don't get it to tight.� I set it with the .004 and check it
> >with the .003.� If the .003 gauge does not go but the .004 does, then it is set
> >properly.
> >Bill
> >>From:
> >>[mailto:
]On Behalf Of Steven Michelsen
> >>Sent: Wednesday, April 06, 2011 2:29 PM
> >>To:
> >>Hey Mike,
> >>The book says .004".� See the bottom half of this page.
> >>Steve
> >>>From: Mega
> >>>To:
> >>>Sent: Wednesday, April 06, 2011 5:19 PM
> >>>Subject: [anzhonda600owners] corrected valve clearance.
> >>>thanks again,
> >>>Mike.
Blake,it is all good. Everytime I come to this site I get some info that helps me with my coupe. I post stuff that "hopefully" is useful in some way. This is a very small group of owners, and very few of us post anything.
Bill has helped me alot, so I was defending him.
Sorry for jumping on you.
Honda 600 folks have to stick together.
Back to valve adjustment, I set mine as close to .003"-.004" as I could get. I did grind the rocker arms(valve end)to get a good surface, only removed about.003". I still had plenty of adjustment on the eccentric shafts.
See photo section.
See photo section.
> new. It's all good.
> Blake
> From: Lyle
> Sent: Thu, April 14, 2011 1:33:38 AM
> Subject: [anzhonda600owners] Re: corrected valve clearance.
> folks.....for free!
> Lighten up!
> Lyle
, blake neilson
> > In other words, if a .004 is a go how could a .003 (a thinner feeler gauge)Â
> > would also be a go.
> > Â
> > Â
> > From: "billmyong@"
> > Â
> > Â
> >at
> >face?Â
> > much torque on the rocker arm bolt causing a dimple in the rocker arm shaft.Â
> >If
> >you
> >rocker
> > arm face
> > Â
> > valve clearance.
> > Â
> > Â
> > Â
> > Â
> > >From:
> > >[mailto:
> > >To:
> > >Â
> > From: blake neilson
> > >To:
> > >Â
> > From: "billmyong@"
> > >To:
> > >Â
> >check it
> >set
> > >properly.
> > >Â
> > >Bill
> > >Â
> > >Â
> > >>From:
> > >>[mailto:
> > >>To:
> > >>Â
> > >>Hey Mike,
> > >>Â
> > >>Â
> > >>Steve
> > >>Â
> > >>>From: Mega
> > >>>To:
> > >>>Â
> >went
> > >>>thanks again,
> > >>>Mike.
