Re: [2cylinderhondas] Brake Pads and Caliper Kits
Shoes and pads can also be relined.  With new and Normally better materials.
> 2cylinderhondas@yahoogroups.com [mailto:2cylinderhondas@yahoogroups.com] > On > Behalf Of > jbmkwaj@...
> Friday, October 07, 2011 9:49
> Rock Auto has rear brake shoes for
> $12.02 for a set of four and caliper kits for $7.00. Seems like a better deal > -- thats what I used -- shop around people........
> -----Original
> Message-----
> From: theenginebuilder
> To: 2cylinderhondas
> Sent: Thu, Oct 6, 2011 2:38
> pm
> Subject: [2cylinderhondas] Brake Pads and Caliper Kits
> Brake pads and caliper kits have been added.
> http://www.honda600carparts.com/brakes
I noticed that there is a statement that cast iron cylinders last longer than aluminum ones.  Not true, both will corrode with time and lack of fluid changes and maintenance.  Both need sleeving to be corrosion resistant.  Many of the cylinders that fail a rebuild are due to the pistons which corrode under the seal causing a leak.  So having a cast-iron brake cylinder with aluminum pistons has as much or more of a chance to corrode because of dissimilar metals. Brass sleeving of an original brake cylinder, although more costly will last the test of time.  Switching to a cup type seal to ride against the piston will remove almost all chances of failure due to internal cylinder corrosion.
> 2cylinderhondas@yahoogroups.com [mailto:2cylinderhondas@yahoogroups.com] > On > Behalf Of > theenginebuilder > Sent:
> Thursday, October 06, 2011 2:39
