That may be true, and it is not just this site I am speaking of. There were people selling vinyl tubing to be used with brake fluid that was made for water. The seals pictured are not directional and there is no mention of the material they are made of. If it were a substantiated company such as Beck Arnley or WIX there would be no hesitation and I would agree.
But who knows? Oh they may run for a while but why would Honda make them directional if it didn't have to? And, if the O rings are made of Natural Rubber they will swell when used with oil and there will be leaks.
Anyone can take an old O ring and the application into a manufacturer and get qualified and professional assistance as to the product they need, and although they may not be able to sell you the part. Normally they will tell you who in your area has them or can order them.
> 2cylinderhondas@yahoogroups.com [mailto:2cylinderhondas@yahoogroups.com] > On > Behalf Of > robertjritter > Sent:
> Sunday, October 16, 2011 4:49
> [2cylinderhondas] Re: More Parts Added
> I have bought many parts from this site and have been very happy with all > the parts I have received and the custom service.
> > I wouldn't go so far as to
> qualify these as good parts. Something off the
> > shelf for a different
> application may not work and cause more problems than
> > you had to begin
> with. Natural Rubber works well with water but not with
> > oil, there are
> a bunch of O rings out there made for a different purpose.
> > Many of the
> shaft seals sold by Honda are directional. None of the seals > > listed > have that capacity. Often a seal is not all that is needed to > > correct > the problem, the sealing surface may also need repair. It may fit > > the > housing but will it seal against the rotating shaft? You may have
> noticed the Fan Mount cushions on your engine swelling because of oil
> leaking onto them. If you replaced them with Neoprene rubber they will
> resist swelling and last much longer. The question - have they been > tested > > on a Honda 600 engine? for how long and with what result? In a > vehicle or > > just on a test stand?
> ]On
> Behalf Of Mark P Hatten
> > Sent: Saturday, October 15, 2011 5:27
> Subject: RE: [2cylinderhondas] More Parts Added
> > Awesome ! you've got some very much needed parts for great > prices
> http://www.mphspecialties.com/
> From: theenginebuilder@...
> > Date: Sat, 15 Oct 2011 22:18:32
> +0000
> > Subject: [2cylinderhondas] More Parts Added
> > More new parts added.
> http://www.honda600carparts.com
