Hey guys. I've started making more of these since the one I used in my car worked so good. I'm listing them on Ebay as I make them. I've got one right now, and I've started putting together another one.
Here's the ebay link:
http://www.ebay.com/itm/Honda-600-Cam-C ... es&vxp=mtr
Cam Chain Tensioner - it's finally here.
joe johnson
Re: Cam Chain Tensioner - it's finally here.
Does this Cam Chain Tensioner Have a sleeve for a bearing surface. Please let me know. Thanks
Wed, 1/4/12, Mike
> From: Mike
> Subject: [anzhonda600owners] Cam Chain Tensioner - it's finally here.
> Date: Wednesday, January 4, 2012, 1:48 PM
joe johnson
resend
Sun, 1/8/12, joe johnson
> From: joe johnson
> Subject: Re: [anzhonda600owners] Cam Chain Tensioner - it's finally here.
> Date: Sunday, January 8, 2012, 10:34 AM
> Does this Cam Chain Tensioner Have a sleeve for a bearing surface. Please let me know. Thanks > --- On > Wed, 1/4/12, Mike > > wrote:
> > From: Mike
Joe,
Yes it sort of does. The bearing insert actually is encased in a sleeve for the roller pins of the bearing to roll on. The inner sleeve is the old bushing from the part. The bearing is made to fit it perfectly.
Here are some pictures to better describe what I'm talking about:
These two pictures show the wheel with the bearing inserted. You can sort of see the sides of the bearing's case. The case goes around the outside of the rollers and acts as an outer sleeve.
http://i81.photobucket.com/albums/j228/ ... C00302.jpg
In this one, I'm holding the roller bushing above in my fingers:
http://i81.photobucket.com/albums/j228/ ... C00303.jpg
And in this picture, you can see the roller bushing sitting inside the bushing:
http://i81.photobucket.com/albums/j228/ ... C00304.jpg
The wheel is then held in the tensioner arm using the same old pin that has the oil collecting thingy on the side and the oiling holes in the middle to ensure the bearing is constantly well lubed.
Hope these pics help.
Mike.
Mike.
> --- On Wed, 1/4/12, Mike wrote:
> From: Mike
