If you are aware of anything or anyone else that belongs here, please email me or write about it here.
http://honda600coupe.com/Honda_600_Coup ... ility.html
> Mike
> Tuesday, January 10, 2012 11:15
> [anzhonda600owners] Re: Cam
> Chain Tensioner - it's finally here.
> Joe,
> Yes it sort of does. The bearing insert actually is encased > in a sleeve for the roller pins of the bearing to roll on. The inner sleeve is > the old bushing from the part. The bearing is made to fit it > perfectly.
> Here are some pictures to better describe what I'm talking > about:
> These two pictures show the wheel with the bearing inserted. You > can sort of see the sides of the bearing's case. The case goes around the > outside of the rollers and acts as an outer sleeve.
> http://i81.photobucket.com/albums/j228/ ... C00302.jpg > In > this one, I'm holding the roller bushing above in my fingers:
> http://i81.photobucket.com/albums/j228/ ... C00303.jpg > And > in this picture, you can see the roller bushing sitting inside the > bushing:
> http://i81.photobucket.com/albums/j228/ ... C00304.jpg > The > wheel is then held in the tensioner arm using the same old pin that has the > oil collecting thingy on the side and the oiling holes in the middle to ensure > the bearing is constantly well lubed.
> Hope these pics
> help.
> Mike.
> joe johnson wrote:
> > Does this Cam
> Chain Tensioner Have a sleeve for a bearing surface. Please let me know.
> Thanks
> > --- On Wed, 1/4/12, Mike
> > From: Mike
> [anzhonda600owners] Cam Chain Tensioner - it's finally here.
> Date: Wednesday, January 4, 2012, 1:48 PM
> > Hey guys. I've
> started making more of these since the one I used in my car worked so good.
> I'm listing them on Ebay as I make them. I've got one right now, and I've > started putting together another one.
> Here's the ebay link:
> http://www.ebay.com/itm/Honda-600-Cam-C ... es&vxp=mtr
