Does anyone in socal have a vacuum advance from a coupe they are willing to part with? Im in the middle of doing my points and noticed the advance is not functioning properly. The sooner I can get it the better. please let me know,
Eddie
Vacuum advance
Mike McGregor
Re: Vacuum advance
Saw this one on Ebay:
http://www.ebay.com/itm/HONDA-600-COUPE ... 5891a95da6
It looks kind of worn out, but the guy says he bench tested it and it works.
good luck
EDDIES To:
Wednesday, February 29, 2012 2:44 PM Subject:
[anzhonda600owners] Vacuum advance
Does anyone in socal have a vacuum advance from a coupe they are willing to part with? Im in the middle of doing my points and noticed the advance is not functioning properly. The sooner I can get it the better. please let me know, Eddie
good luck
EDDIES To:
EDDIE SINCOMB
Re: Vacuum advance
Thank you, I saw that one as well. The vacuum nipple is in a different spot which leads me to believe its from a sedan.
>good luck
>From: EDDIES To:
>Sent: Wednesday, February 29, 2012 2:44 PM
>Subject: [anzhonda600owners] Vacuum advance
>Eddie
Re: Vacuum advance
Hi Eddies;
It does not matter, some were after market, both fit on either car.
> EDDIE
> SINCOMB
> Wednesday, February 29, 2012 1:31 PM
> Re: [anzhonda600owners]
> Vacuum advance
> Thank you, I saw that one as well. The vacuum nipple is in a different > spot which leads me to believe its from a sedan.
> >Saw this one on
> Ebay:
> >It
> looks kind of worn out, but the guy says he bench tested it and it > works.
> >good
> luck
> >From:
> EDDIES eddieinps@...
> >To:
> >Subject:
> >Does
> anyone in socal have a vacuum advance from a coupe they are willing to part > with? Im in the middle of doing my points and noticed the advance is not > functioning properly. The sooner I can get it the better. please let me > know,
> >Eddie
Matthew Brecount
Re: Vacuum advance
Need Gaskets, any clues, who has some?
Re: Vacuum advance
Matthew B;
There are more of them coming up all the time. Some are made so thin that when the cam ends (the cap/bearing for the ends of the cam) are put on they rub against the cam lobe on the ends of the cam and can seize the engine. Also, a too thin gasket for the cam box will literally burn up. The preferred gasket material is asbestos, I have them but you have to cut them out yourself. Simple to do and the fibers are incased so there is no chance of inhaling the fibers. The fibers are glued together with a mastic in production so there is little chance of the fibers becoming air born, but when cutting them I ware a particle mask just to be safe. I do the same when working with brake pads and shoes.
> Matthew
> Brecount
> Saturday, March 03, 2012 9:32 AM
> RE: [anzhonda600owners]
> Vacuum advance
> billmyong@...
> Date: Thu, 1 Mar 2012 22:45:07 -0800
> RE: [anzhonda600owners] Vacuum advance
> Hi Eddies;
> either car.
> > On Behalf Of
> > EDDIE
> > SINCOMB
> > Vacuum advance
> > Thank you, I saw that one as well. The vacuum nipple is in a > > different spot which leads me to believe its from a sedan.
> > >Saw this one on
> > Ebay:
> > >It
> > looks kind of worn out, but the guy says he bench tested it and it > > works.
> > >good
> > luck
> > >From:
> > EDDIES > eddieinps@...
> > >To:
> > >Subject:
> > >Does anyone in socal have a vacuum advance from a coupe they are > > willing to part with? Im in the middle of doing my points and noticed the > > advance is not functioning properly. The sooner I can get it the better.
> > please let me
> > know,
> > >Eddie
Re: Vacuum advance
Same here lol I was just about to ask if anyone knew of anywhere to get some.
Sent from my iPhone
Sent from my iPhone
billmyong@...
Subject: RE: [anzhonda600owners] Vacuum advance
Hi Eddies;
> EDDIE SINCOMB
> Re: [anzhonda600owners] Vacuum advance
> >good luck
> >From: EDDIES eddieinps@...
> >To:
> >Eddie
