master cylinder
r savard
master cylinder
Post by r savard »
Howdy,  Anyone know what master cylinder and wheel cylinder fit on the 600?
Re: master cylinder
I thought I would share a Thread repair item that I have used for many years.   The prep (drilling out the old thresds) is critical, but the repair is outstanding.  The repair uses a regular bolt, I put a knock pin (like the one used on the stater cover on the Honda 600 engine) between the "Seal-Lock nut" and the nut on the bolt to thread the "Seal-Lock nut" further into the case.  But I have used these to repair the threads on the intake manifold threads in the head.  Drilling caused the threads to open the intake area and the Seal-Lock nut sealed the hole so there was no vacuum leak.  They even make them small enough to fix the threads on the Honda 600 carb.
http://www.angelfire.com/biz/thread/
Note: 1 image(s) originally linked in this post are no longer available (nc3=3848643).
