i saw the "how to" on replacing spark plug wires in the coil. Can someone recommend a good set of replacement wires to use for this job.
Thanks
new spark plug wires.
Re: new spark plug wires.
6mm dia. wire and if you can get some real wire from an off road shop that would be best.
> eric.geiger
> Thursday, September 06, 2012 9:48
> [anzhonda600owners] new spark plug wires.
> i saw the "how to" on replacing spark plug wires in the coil. Can someone > recommend a good set of replacement wires to use for this > job.
> Thanks
6mm? i thought i read 8mm while searching online through the groups. can you confirm please
Eric J. Geiger
PRG Nocturne
XXX-XXX-XXXX phone
XXX-XXX-XXXX fax
XXX-XXX-XXXX mobile
egeiger@...
www.prgnocturne.com
On Sep 7, 2012, at 6:46 AM, 6mm dia. wire and if you can get some real wire from an off road shop that would be best.
> > On Behalf Of
> > eric.geiger
> > Thursday, September 06, 2012 9:48 PM
> > Thanks
Eric J. Geiger
PRG Nocturne
XXX-XXX-XXXX phone
XXX-XXX-XXXX fax
XXX-XXX-XXXX mobile
egeiger@...
www.prgnocturne.com
> > On Behalf Of
> > eric.geiger
> > Thanks
