Re: [2cylinderhondas] Seat belt tensioners
I like spray silicone.  WD will work,but it collects dust.
Pull the belt assembly and pull it all the way out on the real, then use the spray silicone liberally and cycle the belt back in several times.  If there is any wear or damage that will have to be straightened.  Otherwise it should work fine.
Robert James
Post by Robert James »
Thanks, will give it a shot.
Bob
On Wed, Aug 28, 2013 at 10:43 PM, Bill
> I like spray silicone.� WD will work,but it
> collects dust.�
> the real, then use the spray silicone liberally and cycle the belt back in > several times.� If there is any wear or damage that will have to be > straightened.� Otherwise it should work fine.
> bobs600honda
> Wednesday, August 28, 2013 5:57
> Any trick to getting the front seat belts to retract full? Oil / graphite / > grease?
> Thanks for any suggestions,
> Bob
Robert James
Silicone spray did the trick.
But, what's up with yahoo site new format? �Cannot figure out how to search messages. �Maybe because I am using the wife's ipad.
> collects dust.�
> bobs600honda
> Bob
