Brand new owner of 600 sedan
ericksonj0705
So bought this project car. Runs, no brakes (emergency work), gears work (got it to 4th ) on the road (to 50mph). Wondering where to start with the refrib. Would like to show it off asap. Have the money to work on it ($1500). Any ideas? Joshatc
Re: Brand new owner of 600 sedan
sounds like brakes from your description.
Eric J. Geiger
PRG Nocturne
XXX-XXX-XXXX phone
XXX-XXX-XXXX fax
XXX-XXX-XXXX mobile
egeiger@...
www.prgnocturne.com
On Sep 17, 2013, at 8:19 PM, So bought this project car. Runs, no brakes (emergency work), gears work (got it to 4th ) on the road (to 50mph). Wondering where to start with the refrib. Would like to show it off asap. Have the money to work on it ($1500). Any ideas? Joshatc
Eric J. Geiger
PRG Nocturne
XXX-XXX-XXXX phone
XXX-XXX-XXXX fax
XXX-XXX-XXXX mobile
egeiger@...
www.prgnocturne.com
I'd start on the brakes. And not leave the shop until they really work Running down the road at 50 mph and only the emergency brakes work? In a real emergency, ALL you'll have is a prayer.
- - - - - - - - - - - - - - - - - - - - John Graf
ericksonj0705
Ok, that was dumb of me, Dah. Who should i send my send my master cyl. too and should i automatically rebuild the individual cyl.?
Eric J. Geiger
PRG Nocturne
XXX-XXX-XXXX
phone
XXX-XXX-XXXX
fax
XXX-XXX-XXXX
mobile
egeiger@...
www.prgnocturne.com
On Sep 17, 2013, at 8:19 PM, > So bought this project car. Runs, no brakes (emergency work), gears work (got it to 4th ) on the road (to 50mph). Wondering where to start with the refrib. Would like to show it off asap. Have the money to work on it ($1500). Any ideas? Joshatc
Eduardo Zamora
Congrats for your new ride, I just sended mine a couple of weeks ago ill stop by tomorrow and ill find out what would be the price for rebuilding the brakes, also I left my clutch and flywheel and my front rotors
> Eric J. Geiger
> PRG Nocturne
> XXX-XXX-XXXX
> �phone
> XXX-XXX-XXXX
> �fax
> XXX-XXX-XXXX
> �mobile
> egeiger@...
> www.prgnocturne.com
> On Sep 17, 2013, at 8:19 PM, ericksonj0705@...
in reality though yes brakes, then do a good tune up on it. points, condenser, timing adjust, valve adjust, oil change, spark plugs. depending on the amount of miles you may need to look into a timing chain.
also depending on the shape of the ignition coil you may look into getting a new rebuilt coil or rebuilding it yourself. As well as having the carb gone through. I'd do a compression test and see how good the compression is so you know if the engine is worth sticking money into first or if its gonna require more than just some tuning to get running great again.
Also it depends on what your plan is for the car. Just to have a good runner or are you looking to make it a looker as well.
good luck welcome to the club
Eric J. Geiger
PRG Nocturne
XXX-XXX-XXXX phone
XXX-XXX-XXXX fax
XXX-XXX-XXXX mobile
egeiger@...
www.prgnocturne.com
Eric J. Geiger
PRG Nocturne
XXX-XXX-XXXX phone
XXX-XXX-XXXX fax
XXX-XXX-XXXX mobile
egeiger@...
www.prgnocturne.com
> Eric J. Geiger
> PRG Nocturne
> XXX-XXX-XXXX
> phone
> XXX-XXX-XXXX
> fax
> XXX-XXX-XXXX
> mobile
> egeiger@...
> www.prgnocturne.com
Try a rebuild kit if it works go with it if it leaks buy a resleved one and then use the kit that you bought and then you will be golden. I would change the lines and re build the cylinders at the same time Kurt
Eric J. Geiger
PRG Nocturne
XXX-XXX-XXXX
phone
XXX-XXX-XXXX
fax
XXX-XXX-XXXX
mobile
egeiger@...
www.prgnocturne.com
ericksonj0705
After reading my messages. i sound like an idiot. I'm just really excited and want to do this right. Bare with me !
It's all good we've all been in your shoes Kurt
ericksonj0705
Where is the best place to find these kits?
Kurt
> On Sep 17, 2013, at 6:30 PM, ericksonj0705@...
> , anzhonda600owners@yahoogroups.com
