What they should have used is a rubber "U" shaped gasket to fit the glass joining at the bottom of the glass and then install the gasket into the hatch using 3M Window-Weld ribbon sealer. 3M part number 08612. However if this is the first time your installing glass using this seal a auto glass installation company may be a better choice as there are cleaners for the glass and the hatch frame to make this a lasting seal.
Some of the U shaped seals have a chrome inset which is closer to the look that the Honda 600 coupe had.
HONDA 600 COUPE Hatch glass seal
Re: HONDA 600 COUPE Hatch glass seal
Hi Bob,
I just posted a msg about a silicone sealer before I saw this response from Bill. So, you can ignore my message since this has the 3M product which is made specifically for your application.
Thanks, Bill, for your advice.
good luck on your project,
> used is a rubber "U" shaped gasket to fit the glass joining at the bottom of > the glass and then install the gasket into the hatch using 3M Window-Weld > ribbon sealer. 3M part number 08612. However if this is the first > time your installing glass using this seal a auto glass installation company > may be a better choice as there are cleaners for the glass and the hatch frame > to make this a lasting seal.
> have a chrome inset which is closer to the look that the Honda 600 coupe > had.
> [mailto:2cylinderhondas@yahoogroups.com]
> rjamesblues@...
> Sunday, April 27, 2014 7:57
> [2cylinderhondas] HONDA 600 SEDAN/COUPE WINDSHIELD SEAL (REPRODUCTION > )
> http://www.ebay.com/itm/1970-TO-1972-HO ... 1333950577
> Is anyone aware of where to get a rear window seal for coupe?
> I have seen this on ebay and it states it is good for both the front > windshield and rear window.
> Previous owner used a bunch of black goo and it looks like hell!
> Thanks for any pointers!
> Bob (Tracy, CA)
Hi Dale;
I had the parts page from an Italian Honda Coupe parts manual. It seems that they were allowed to purchase all the parts to replace the glass in the coupe hatch, so there are parts numbers for them but I could never order them.
The chrome strip was really an L shaped affair that slipped between the glass and the frame to the hatch.
I have had some success using an aftermarket wheel flair chrome strip that was L shaped with adhesive on one side.
When it came to the corners letting it sit in the sun for a while made it pliable enough to stretch it around them making for a good fit.
It was on the car for a month or so before I sold it so no history on how long it held up .
I have a set of NOS rear hatch chrome for a coupe. Not for sale though sorry.
PRG-Nocturne
XXX-XXX-XXXX
Egeiger@...
PRG-Nocturne
XXX-XXX-XXXX
Egeiger@...
On Apr 28, 2014, at 2:42 PM, "Bill" wrote:
Hi Dale;
I had the parts page from an Italian Honda Coupe parts manual. It seems that they were allowed to purchase all the parts to replace the glass in the coupe hatch, so there are parts numbers for them but I could never order them. The chrome strip was really an L shaped affair that slipped between the glass and the frame to the hatch.
mailto:anzhonda600owners@yahoogroups.com
On Behalf Of
goinhm@...
Monday, April 28, 2014 10:22 AM
Re: [anzhonda600owners] HONDA 600 COUPE Hatch glass seal
Hi Bob,
> What they should have used is a rubber "U" shaped gasket to fit the glass joining at the bottom of the glass and then install the gasket into the > hatch using 3M Window-Weld ribbon sealer. 3M part number 08612. However if this is the first time your installing glass using this seal a auto glass installation company may be a better choice as there are cleaners for the glass and the hatch frame to make > this a lasting seal.
> rjamesblues@...
> Sunday, April 27, 2014 7:57 PM
> [2cylinderhondas] HONDA 600 SEDAN/COUPE WINDSHIELD SEAL (REPRODUCTION )
> I have seen this on ebay and it states it is good for both the front windshield and rear window.
> Bob (Tracy, CA)
