brake booster vs. tee vs. alternative master cylinder ?
michael_wasilewskicst
Post by michael_wasilewskicst »
Hello all,
I am quite sure this has been a subject of a discussion before. Does any one knows about a tee element that could replace the booster or a new set up that could work, including a different master cylinder ? Thanks a lot, Mike
Re: brake booster vs. tee vs. alternative master cylinder ?
Hi Mike;
There are several master cylinders people have used and posted here on the group with their ideas.  There are also some shops that will rebuild your breaks alleviating the need to custom make parts or things that will make it work.
But if it is a sedan the rear brake hose will screw into the existing fittings removing the booster.
The Coupe is a bit more difficult, requiring disassembly of the booster and plugging the ends and using the fittings to connect it like a part of the line.
A shop on the east coast called White Post Restorations ( www.whitepost.com ).
Pull the master cylinder, wheel cylinders or calipers, leave them all together and send em to them as they state on their site and everything comes back ready to install.
White Post will do the boosters (they did mine) but you have to provide the rubber diaphragm.
They have a good turn around time and I have no faults with their work.
Michael Wasilewski
Post by Michael Wasilewski »
Thank you Bill, I will follow up with your lead.
Do you know if there have been successful transplants from other cars ?
On Tuesday, July 22, 2014 7:28 PM, "'Bill' billmyong@... [anzhonda600owners]" wrote:
Hi Mike;
Nothing that I have tried.  But there were some posts on the group that found master cylinders that will work.
