New 600 performance parts website!
tgm_enterprizes
Its rare to have another website for our car, much less one making performance parts.
Well I took the plunge and decided I needed to publicly offer the parts I make to everyone worldwide.
http://honda600performance.com
Let me know what you think. And if you have an idea of something I can make, let me know!
Richard (Rick) Morris
Mark P Hatten
Re: New 600 performance parts website!
This is awesome
Sent from Hotmail Email App for Android
Sunday, 11 August 2019, 08:35AM -07:00 from tgm_enterprizes@... [anzhonda600owners] anzhonda600owners@yahoogroups.com:
Thanks.
Richard Morris
Honda600performance.com Sent from my iPhone
Richard Morris
On Aug 11, 2019, at 1:15 PM, Mark P Hatten
mphatten@...
[anzhonda600owners] wrote:
This is awesome
tgm_enterprizes@...
[anzhonda600owners]
Mark P Hatten
Richard , I have an idea for a much needed and fantastic performance part for our Honda 600's
Electronic Ignition Conversion Kit
Every Honda 600 car needs one
Mark
anzhonda600owners@yahoogroups.com on behalf of Mark P Hatten mphatten@... [anzhonda600owners]
Sunday, August 11, 2019 6:15 PM
Re: [anzhonda600owners] New 600 performance parts website!
This is awesome
anzhonda600owners@yahoogroups.com :
Mark
This is awesome
Mario Espinoza
AMEN!!
Sent from iPhone Mario Espinoza Notary Public
On Aug 12, 2019, at 8:02 AM, Mark P Hatten
mphatten@...
Mark
mphatten@...
[anzhonda600owners]
dgrandinett
I installed a standard MSD 6AL Capacitive Discharge electronic ignition system (with an HD Sport coil) which has been working great.
It did make a HUGE difference particularly with start-up which is now instantaneous even when cold. In addition the points seem to last forever and the plugs stay clean and clear.
The control box neatly mounts behind the battery (requires deleting the two speed fan resistor) and I opted to relocate the coil to the dashpanel below the cowl to clean up the "rad" support.
So far, I'd recommend giving it a try-- worked for me.
On August 12, 2019 at 1:33 PM "Mario Espinoza notarydocsla@... [anzhonda600owners]" wrote:
AMEN!!
mphatten@...
> Richard , I have an idea for a much needed and fantastic performance part for our Honda 600's > Electronic Ignition Conversion Kit > Every Honda 600 car needs one > Mark
> mphatten@...
> This is awesome
> tgm_enterprizes@...
> [anzhonda600owners]
> > It’s rare to have another website for our car, much less one making performance parts.
Mark P Hatten
Re[2]: [anzhonda600owners] New 600 performance parts website!
Yes I've installed and MSD Ignition on my Honda 600 as well but I want to do away with the points altogether
Thanks mark
Monday, 12 August 2019, 00:28PM -07:00 from D & K Grandinett grandinett@... [anzhonda600owners] anzhonda600owners@yahoogroups.com:
Thanks mark
> > notarydocsla@...
> > [anzhonda600owners]" > anzhonda600owners@yahoogroups.com
> > > wrote:
> > AMEN!!
> > mphatten@...
> > [anzhonda600owners] > anzhonda600owners@yahoogroups.com
> > > Mark
> > > mphatten@...
> > > [anzhonda600owners] > > anzhonda600owners@yahoogroups.com
> > > Sent:
> > > This is awesome
> > > tgm_enterprizes@...
> > > [anzhonda600owners]
I respectfully disagree. A well adjusted Honda 600 motor with correct point and plug gaps, properly functioning - breaker plate, coil, coil wires and carb will keep it running properly. Electronic Ignition will not fix the other worn parts.
tgm_enterprizes
I have a pertronix igniter that is on a 600 advance plate. Its 1/2 the issue, the other piece to this is on the rotor. It has to be machined in order to mount the round piece that I think contains the magnets.
I only have one and I did a rough estimate of what I would need to get and if the pertronix igniter is used, it would end up being about $175. BUT, the system you really want is the pertronix igniter II (protected against you wiring it wrong and some other things) of course its more expensive, but if I was to make this, I would have to use the version 2 since I dont want to deal with someone blowing up the module and saying it was my fault.
I have 2 MSD 6AL boxes, how do you wire them up for the 600s?
P.s. on my website, you can scroll through the pictures I put on there and you will see that I use Accel super coil as my coil. It has 2 outputs and has the hottest spark of any coil you can get. Its like 80,000volts or more, (I am old and forget). It also had a gigantic effect on the engine starting and I havent had any high RPM miss since I put it on. I put it right where the old coil was (see picture).
Richard
Honda600Performance.com
Richard
I remember in the "'80's way back" Miroslav (Mike) Kefurt of the Honda Car Club in North Hollywood
offered performance items which included a 1 piece front clip, racing clutch disc, rear disc
brake kit. A few years back I contracted with Arias Pistons to make me the exact J&J pistons
kit using drawings & photos I supplied (no way I am releasing my only set) but what they sent me was nothing
like my specs. I think they were 75.5mm and I had Steve Allen make me matching head gaskets.
