New tires are wearing out fast!
Re: Ceat Tires
Yea know.  I would look the front end over and make sure there are no bent or damaged areas.  Then use a tape measure and make a horozantal chalk mark on each tire two inches off the ground.  Loosen the tye rod nuts and measure the distance at the marks on the middle tire tred, now roll the car back and measure the same chalk marks from the rear of the tire from the same tread.  Move the tye rod arms equally on each side until the measure is the same by measuring the chalk marks front and back.  Toe in is so slight that dead on is almost there.  Besides, I paid $25.00 bucks to watch an alignment shop do the same thing.  Yea, it was a long time ago, and my tires are still running strong.
> 2cylinderhondas@yahoogroups.com [mailto:2cylinderhondas@yahoogroups.com] > On > Behalf Of > Miles > Sent:
> Tuesday, June 10, 2008 1:10
> [2cylinderhondas] Ceat Tires
> Back when I got my very first Honda 600, I was 19, my dad thought he
> would do me a favor and bought me a set of Ceat brand tires. They > were > bias ply and the worst tires I have ever had to this day. Even > my rock > hard Michelin snow tires were a better ride!
> I would avoid any Bias
> ply tires unless you are trying to do a 99
> point restore on a 1970 or
> earlier car. The original tires were 5.20
> x 10 Bridgestones.
> Kevin
> - you should take your car down to Lloyd's in Santa Cruz, they > used to do > my alignments. They could also show you what's bent in > your front end.
> scott lesniak
> > I just
> bought 30 tires if anyone needs a set let me know I would > like to get 38 > apiece for them > > I think they are Ceat Tires > > really nice > tread pattern
> > --- On Mon, 6/9/08, Kevin
> misterpoopoohead@ ... wrote:
> > From: Kevin
> > Subject: [2cylinderhondas] New tires are
> wearing out fast!
> Date: Monday, June 9, 2008, 2:00 PM
> > Hi Gang,
> > I put new tires on my car
> less than 1000 miles ago and they are
> already
> > noticably worn in
> the front. The front end may not be perfectly
> aligned
> > but I
> wouldn't expect the tires to get worn out in so few miles.
> > I
> bought the Kumho 145/8010's. These are T rated tires. They ride > nice
> > but they are not going to last to long.
> kev
Love
Re: Ceat Tires
Post by Love »
Ceat made both so, call it a tie.  Last time i used a Ceat radial, it was from Italy.
An alignment would probably correct Kevin's wear problem.  Can the car be driven with negligable pulling from either direction?  Jacking up the tire, does it move without the steering wheel moving?
I had a 600 Sedan that pulled badly, and cribbed over 50mph.  The prior owner drove it over a curb at speed.  The lower arm was bent.  Replacing that helped, but it still didn't track true.  Final solution was to replace the bent subframe.
Bruce D.
Santa Clara, CA
----- Original Message ---- From: scott lesniak To: 2cylinderhondas@yahoogroups.com Sent: Tuesday, June 10, 2008 2:09:12 PM Subject: Re: [2cylinderhondas] Ceat Tires
Hey miles do you want to fight or what.LOL
Tue, 6/10/08, scott lesniak
> From: scott lesniak
> To: 2cylinderhondas@ yahoogroups. com
> Date: Tuesday, June 10, 2008, 5:07 PM
> I guess you didn't read the thread These are radials not bias
> and the handle wonderfully I'm not trying to sell them as I last stated I put my last set on my driver,I only have the CAMAC brand left > --- On > Tue, 6/10/08, Miles > > wrote:
> > From: Miles
> > Subject: [2cylinderhondas] Ceat Tires
> > Date: Tuesday, June 10, 2008, 4:10 PM
> > Back when I got my very first Honda 600, I was 19, my dad thought he > > would do me a favor and bought me a set of Ceat brand tires. They > > were bias ply and the worst tires I have ever had to this day. Even > > my rock hard Michelin snow tires were a better ride!
> > I would avoid any Bias ply tires unless you are trying to do a 99 > > point restore on a 1970 or earlier car. The original tires were 5.20 > > x 10 Bridgestones.
> > Kevin - you should take your car down to Lloyd's in Santa Cruz, they > > used to do my alignments. They could also show you what's bent in > > your front end.
> > Miles
> > , scott lesniak
> > > I just bought 30 tires if anyone needs a set let me know I would > > like to get 38 apiece for them
> > > really nice tread pattern
> > > --- On Mon, 6/9/08, Kevin misterpoopoohead@ ... wrote:
> > > From: Kevin misterpoopoohead@ ...
> > > Subject: [2cylinderhondas] New tires are wearing out fast!
> > > Hi Gang,
> > > I put new tires on my car less than 1000 miles ago and they are > > already > > > noticably worn in the front. The front end may not be perfectly > > aligned > > > but I wouldn't expect the tires to get worn out in so few miles.
> > > I bought the Kumho 145/8010's. These are T rated tires. They ride > > nice > > > but they are not going to last to long.
> > > kev
Kevin Lister
Re: Ceat Tires
Post by Kevin Lister »
I'll have to get under it and give it a good once-over.
It doesn't pull to either side at all. It drives pretty nice in fact. However, when it takes more muscle to turn it to one side than it does the other. Noticably so. I recently took apart the steering rack and replaced the shot bushings with bushings that Miles turned on his lathe. I watched him make them in his garage. Pretty cool. ;o) I cleaned up the stuff real good and regreased it all. I also replaced all of the bearings in the belt pulleys and fan assembly. Again, with lots of help from Miles.
The car no longer clunks loudly going into driveways! The car no longer wanders all over the road and is no longer scary to drive over highway 17! I'm gonna focus on the suspension and brakes now that the mechanical stuff under the hood is in good shape. I can't afford to go through front tires every 800 miles or so!
kev
Tue, 6/10/08, Bruce Dewing
Date: Tuesday, June 10, 2008, 10:11 PM
Bruce D.
Santa Clara, CA
Re: Ceat Tires
Kevin;
 Just a suggestion:
    You may have more than sub frame damage, the body may be tweaked too.   Take the car to a body shop with a frame machine along with your (Big Blue) shop manual (it has the Honda 600 body dimensions) and have them measure it.  They may be able to straighten it out.  Purchased one that was hit in the front and rear, the shop pulled here and there and had it lined up in no time.  (I couldn't use another sub frame on the car but the one that was there came off and went back on with no problem after the fix)
> 2cylinderhondas@yahoogroups.com [mailto:2cylinderhondas@yahoogroups.com] > On > Behalf Of > Kevin Lister > Sent:
> Wednesday, June 11, 2008 6:51
> However, when it takes more muscle to turn it to one side than it does > the other. Noticably so. I recently took apart the steering rack and > replaced the shot bushings with bushings that Miles turned on his lathe.
> I watched him make them in his garage. Pretty cool. ;o) I cleaned up the > stuff real good and regreased it all. I also replaced all of the > bearings in the belt pulleys and fan assembly. Again, with lots of help > from Miles.
> The car no longer clunks loudly going into driveways! The car no > longer wanders all over the road and is no longer scary to drive over > highway 17! I'm gonna focus on the suspension and brakes now that the > mechanical stuff under the hood is in good shape. I can't afford to go > through front tires every 800 miles or so!
> kev
> --- On
> > From: Bruce
> > Dewing
> > Subject: Re:
> > 2008, 10:11 PM
> > Ceat
> > made both so, call it a tie.  Last time i used a Ceat radial, it > > was from Italy.
> > An
> > alignment would probably correct Kevin's wear problem.  Can the > > car be driven with negligable pulling from either direction?
> > Jacking up the tire, does it move without the steering wheel > > moving?
> > I
> > had a 600 Sedan that pulled badly, and cribbed over > > 50mph.  The prior owner drove it over a curb at speed.  The > > lower arm was bent.  Replacing that helped, but it still didn't > > track true.  Final solution was to replace the bent > > subframe.
> > Bruce
> > D.
> > Santa
> > Clara, CA
> > From: scott lesniak > com>
> > Sent: Tuesday,
> > Tires
> > --- On
> > > From: scott
> > > lesniak
> > > Subject: Re:
> > > yahoogroups. com
> > > PM
> > > not bias
> > > them as I last stated I put my last set on my driver,I > > > only have the CAMAC brand left > > > --- On > > > Tue, > > > 6/10/08, Miles > > >
> > > wrote:
> > > > From:
> > > > Miles > > > > Subject:
> > > > [2cylinderhondas] Ceat Tires > > > > To: 2cylinderhondas@ > > > > yahoogroups. com > > > > Date: Tuesday, June 10, 2008, 4:10 > > > > PM
> > > > my dad thought he
> > > > me a set of Ceat brand tires. They > > > > were bias ply > > > > and the worst tires I have ever had to this day. Even
> > > > ride!
> > > > or earlier car. The original tires were 5.20 > > > > x 10 > > > > Bridgestones.
> > > > down to Lloyd's in Santa Cruz, they > > > > used to do my > > > > alignments. They could also show you what's bent in
> > > > your front end.
> > > > Miles
> > > > --- In
> > > > 2cylinderhondas@
> > > > yahoogroups. com
> > > > , scott lesniak > > > ..>
> > > > wrote:
> > > > > I just bought 30
> > > > > I think
> > > > they are Ceat Tires
> > > > > really nice tread
> > > > pattern
> > > > > --- On Mon, 6/9/08,
> > > > > Subject:
> > > > [2cylinderhondas] New tires are wearing out > > > > fast!
> > > > > To:
> > > > 2cylinderhondas@
> > > > yahoogroups. com
> > > > 2008, 2:00 PM
> > > > > Hi Gang,
> > > > > I
> > > > put new tires on my car less than 1000 miles ago and > > > > they are > > > > already > > > > > noticably worn in the > > > > front. The front end may not be perfectly > > > > aligned
> > > > > I bought the
> > > > nice
> > > > long.
> > > > kev
Re: Ceat Tires
Post by Miles »
What? I get the Digest Version of the emails, so mine doesn't show up
til around midnight. Any emails between members, I don't see unless I
go to the home page like now.
Party On !
Kevin Lister
Re: Ceat Tires
What do you think they would charge for such a thing?
kev
--- On Thu, 6/12/08,
billmyong@...
billmyong@...
Subject: RE: [2cylinderhondas] Ceat Tires
> Date: Thursday, June 12, 2008, 12:40 AM
> Kevin;
> Just a suggestion:
> be tweaked too.
> your (Big Blue)
> them measure it.
> was hit in the
> lined up in no
> the one that was
> fix)
]On Behalf Of Kevin
> Lister
> Sent: Wednesday, June 11, 2008 6:51 PM
> once-over.
> side than it does
> rack and
> on his lathe. I
> bearings in the
> from Miles.
> drive over
> brakes now that the
> can't afford to go
> kev
> --- On Tue, 6/10/08, Bruce Dewing
> From: Bruce Dewing Subject: Re: [2cylinderhondas] Ceat Tires
> used a Ceat radial,
> it was from Italy.
> over 50mph. The
> was bent.
> Final solution was
> Bruce D.
> Santa Clara, CA
> From: scott lesniak
> --- On Tue, 6/10/08, scott lesniak
> From: scott lesniak com>
> not bias
> not trying to sell
> have the CAMAC
> brand left
> --- On Tue, 6/10/08, Miles
> From: Miles
> Tires
> com
> 4:10 PM
> my dad thought he
> a set of Ceat
> brand tires. They
> I have ever had
> to this day. Even
> were a better
> ride!
> unless you are
> trying to do a 99
> earlier car. The
> x 10 Bridgestones.
> down to Lloyd's
> in Santa Cruz, they
> could also show you
> what's bent in
> your front end.
> --- In 2cylinderhondas@
> yahoogroups. com, scott
> lesniak
> me know I would
> > From: Kevin
> out fast!
> yahoogroups. com
> 2:00 PM
> > Hi Gang,
> ago and they are
> already
> The front end may
> not be perfectly
> aligned
> in so few miles.
> > I bought the Kumho
> tires. They ride
> nice
> last to long.
> > kev
scott lesniak
Re: Ceat Tires
Post by scott lesniak »
Well up here in Pa. They charge a minimum of 250 for a not so bad twwek but I know you guys pay alot more to get stuff done their.
Sat, 6/14/08, Kevin Lister
Date: Saturday, June 14, 2008, 6:32 PM
kev
billmyong@earthlink .net
> Kevin;
> Just a suggestion:
> be tweaked too.
> Take the car to a body shop with a frame machine along with > your (Big Blue) > shop manual (it has the Honda 600 body dimensions) and have > them measure it.
> was hit in the
> lined up in no
> the one that was
> fix)
]On Behalf Of Kevin
> Lister
> once-over.
> fact. However, when it takes more muscle to turn it to one > side than it does > the other. Noticably so. I recently took apart the steering > rack and > replaced the shot bushings with bushings that Miles turned > on his lathe. I > watched him make them in his garage. Pretty cool. ;o) I > cleaned up the stuff > real good and regreased it all. I also replaced all of the > bearings in the > belt pulleys and fan assembly. Again, with lots of help > from Miles.
> longer wanders
> drive over
> brakes now that the
> can't afford to go
> kev
> used a Ceat
radial,
> it was from Italy.
> over 50mph. The
> was bent.
> Final solution was
> Bruce D.
> Santa Clara, CA
> From: scott lesniak
> not bias
> not trying to sell
> them as I last stated I put my last set on my driver,I only > have the CAMAC > brand left
> From: Miles
> Tires
> com
> 4:10 PM
> my dad thought he
> a set of Ceat
> brand tires. They
> I have ever had
> to this day. Even
> were a better
> ride!
> unless you are
> trying to do a 99
> earlier car. The
> x 10 Bridgestones.
> down to Lloyd's
> in Santa Cruz, they
> could also show you
> what's bent in
> your front end.
> lesniak
> > I just
bought 30 tires if
> me know I would
> > From: Kevin
> out fast!
> yahoogroups. com
> 2:00 PM
> > Hi Gang,
> ago and they are
> already
> The front end may
> not be perfectly
> aligned
> the tires to get
worn out
> in so few miles.
> > I bought the Kumho
> tires. They ride
> nice
> last to long.
> > kev
